I've probably just missed your link, but do you have a link to those solar lights? I'm quite impressed by them too!Solar LED light pair arrived yesterday, left it charging for the 24hrs it wanted and quite impressed for £21 for the pair have to say.
Thanks for that link. When I last had solar LED lights they had some LEDs on the sides too, but these created a bit of a sweeping sideways light and I didn't want the light in my windows. The lights you have linked to should be idea, as there will be no sideways light.ah yes sure thing, it's these: Deal: Pxwaxpy Solar Lights Outdoor 【286 LED & 2600 Lumen】 Upgraded Solar Motion Sensor Security Light with 3 Lighting Modes, 2500mAh Solar Powered Wireless Waterproof Wall Lights for Outside (2 Pack) https://www.amazon.co.uk/dp/B08GM2N..._dl_XQF3493BDX2G2VF14G5P?_encoding=UTF8&psc=1
You shouldnt expect it until autumn/winter, then it will be a nightmare, it will literally rain inside the shed on cold frosty nights! My garage was bad enough and that was oduline bitumen sheet roof, metal is worse.So far have not had any issues with condensation ans we have had a couple of stormy wet nights as well. There were a few water leaks as expected with these tin sheds but I have sealed these up on both sides with the black Silka Flex. I've strategically left some gaps for airflow as well so will see how that fairs and have only sealed the concrete slabs on the outside areas leaving the inside slabs basiclaly touching each other so air and any remnant moisture can evaporate through the air channel created by the gaps. Will keep monitoring it though of course and update as necessary.
If/when that happens, best solution? Line the outside panels and roof with a material that stops or reduces condensation buildup?
