Shortcut for switching sheets in Excel?
20 Oct 2002
London
I'm doing some coursework and using different worksheets in Excel on Mac. (Different windows, not tabs)
Clicking 'Window' on the top-bar and finding the right sheet is tedious.. is there not a keyboard shortcut to cycle through worksheets as you can for tabs? :confused:
CMD + Page Up (Left) or Page Down (Right).
That cycles through tabs, not worksheets.
You mean workbooks (the "tabs" are worksheets - https://www.excel-easy.com/basics/worksheets.html)?
If you're fullscreen'd then you can cycle apps/windows using CTRL+Left/Right. Otherwise you can right-mouse click the dock icon to select a workbook or, install a alt-tab switcher like AltTab (https://forums.overclockers.co.uk/t...cations-thread.18927576/page-19#post-36703311) to give you something a bit more like the switcher in Windows.
Not quite what you want but if you're using a trackpad, do it via Mission Control? Swipe up with four fingers and click on the other window?
If I have multiple workbooks open I use Command ` to cycle through the sheets
Just hold the command button and then every time you click ` (next to Z) it will cycle through
