Should i rma wd drive?
10 Apr 2006
Edinburgh
I sold my old pc but it came back a week later bsod whenever anybody tried to log on,traced it back to hd which is a western digital 800 (80gb) pata drive.
Its 2 1/2 yrs old and still warrantied till end of year.
I used the wd diagnostic tools,it passed a quick test but has found bad sectors on long test.
Should i rma drive as is without trying to repair?.It caused major mf on my old pc and def wouldn`t use it as a primary.Bad sectors to me usually means drive is on way out.
I know,you`re probably thinking `tight git buy a new one` :D but this ones going in my friends pc which now only has a measly 10gb drive.I get old pcs fix em up and give em away to friends as basic internet machines.
Any experience with wd?
Cheers
If your HDD is acting up and you still have warranty left - use it!
I wouldn't care if someone though of me as being a tight git. You paid for that warranty so why shouldn't you use it?
Usually when running a test you get given a diagnostic code that you enter into an online form.
Just go to WDs website and look for their RMA system. Should all be explained there.
SiriusB
excactly... get it RMA'd!!!
Cheers Sirius,the program said it had fixed bad sectors,just did another 1 1/2 hr pass and it went ok this time hmm.
Under those conditions i can`t send it back,they would just send it back to me their website is pretty detailed on what constitutes an rma.Site did say any error showing up twice qualifies for a replacement.
I`ll use it for an os in an old machine,if its going to go that`ll surely show it up.
