- 9 Aug 2020
I know I can shuck my hard drive, but it has data on. Can I just take it out of it's enclosure and connect via sata and all will be well?
Depends on which model external you have, there's a possibility it could have hardware encryption in the USB SATA bridge. If it does you'd have to copy the data to another drive, reformat after shucking, then copy the data back.I know I can shuck my hard drive, but it has data on. Can I just take it out of it's enclosure and connect via sata and all will be well?
Some WD drives don't let you do this. There's some kind of encryption or similar meaning you can't read any data from them when removed from the enclosure.
Iirc with the last WD drive I shucked, you had to do something with the header pins.
Mine is a
WD 16 TB Elements Desktop External Hard Drive
Plug and play?
You can shuck that but you have to cover the first 3 or just the 3rd sata pin with kapton tape to make it work on a pc.
Electrical tape will do
I find kapton tape better, electrical tape tends to come off when you remove the power connector and it leaves behind a sticky residue.Electrical tape will do
Yeap, worked fine on my main PC. However I think it is depends on what PSU you have, the drive worked without tape on another system.
I prefer kapton tape as electrical tape is thicc and less prone to breaking the sata connector if you change drives a lot.
Good to know. which width in mm do you go for?
.Or using Molex to SATA adapter for power.Electrical tape will do
