shutdown after update = problems
21 Dec 2006
Earlier today I did a software update on my Mac Pro which it has been asking me to do for a while, but I have just kept putting off.
Fast forward an hour an it has been sat on the default desktop background for about 50 minutes after it finished installing etc.
I waited another half an hour just in case and nothing had changed, so I held the power button down to turn it off.
When i restarted, my desktop background image had been changed to the default image and the start bar across the top of the screen was invisible, which just an outline of the spotlight icon visible.
Finder would say "the application Finder can't be opened. -10810" when I click on it and nearly every other app wont load.
Eventually, after a few forced shutdowns/restarts the start bar showed up and some software would load, but it seems random as one minute it will work and the next time it wont.
I also cant restart/shut down properly from the start bar as it just sits there doing nothing after I click it.
Have I totally screwed my Mac, or is there some way to fix it without doing a complete fresh install?
Download the Combo update (somehow): http://support.apple.com/kb/DL1324
If you can, run it.
If not try:
1. Running in safe mode and running some commands, but I've never had to do this so I don't really know what goes on here so give it a google.
2. Boot off the OS X install disk and run disk check and verify permissions.
Try and install the update again.
If none of the above fixes it then I'm afraid it's reinstall time.
