Shuttle SP35P2 Pro Raid problems
29 Oct 2003
Perivale, London
Hi,
my SP35 has been setup to run raid 1 and its been going fine for a while but the other day i see that i now had two hard drives showing in my computer and i wasn’t until today that i see that on startup i wasn’t seeing the raid check screen so i have checked the bios and found that the shuttle has gone back to IDE mode and not RAID as it should be but now the two drives are different in size so the shuttle will not boot up pass the verfing data pool screen or what ever is saids.
what should i do to get the raid config to re-copy the data to the second drive again ?
If i re-format the second drive in vista and the change the bios back to RAID will i then get the option to copy the drive back to RAID again ?
Tony
