- 25 Nov 2002
- Somerset
This is a weird one... The design is fundamentally floored because, the reviewer suspects, that the VRMS can't push the CPU beyond 4.4Ghz. Why go for an enthusiast platform in a small box, effectively crippling it so that it can't compete evenly with m-ITX Z77/Z68 solutions?
I am not trying to say that. I'm confident that the hardware can cope but that Shuttle have put in software (Bios) code that prevents the power getting used.
If Shuttle remove this restriction the machine will be very powerful and as it should be.
I have passed this information back to Shuttle and await thier response.
Linky seems broken in first post.
Hello Simon,
I have a shuttle sx79r5 with the same configuration that you exhibit in your review. As you have done to set the mSATA as hard disk cache. When I install the rste, there is no way to configure it so.
thank you very much
Are you running the machine with RAID enabled in the bios? It must be in RAID mode to enable using the disk as a cache.
Please just email him directly using the Trust button instead of all these posts. Thanks
