krooton said:Noctua or Nexus
Chris Beard said:Nexus = Yate Loon
Seconded, I've had Yate Loons before but now I use Sharkoon SE 1000s and they are better however just a little bit more expensiveGonzo0 said:Sharkoon Silent eagle 1000
They get custom PC's premium grade![]()
mr_x_plosion said:I have Sharkoon 2000's due tomorrow so ill let out know what they are like.
36.1 dB(a) isn't whisper silentGonzo0 said:You wont be dissapointed, whisper silent and look the shizz![]()
)Wayne, do you happen to have both 120mm SE1000 and a 80mm SE2000 fans?Big.Wayne said:Sharkoon 'Silent Eagle' 2000 series are not 'whisper quiet'. The 80mm versions do produce an audible 'whoosing' sound from the air they move and the 120mm even more so (the latter really moves allot of air!!).
Both the 2000 series fans are ideal if you have and are using the motherboards built in fan control (i.e Q-Fan etc). In my system the 80mm/2000's run on average at 1400rpm but if things warm up they speed up all the way to 2200rpm (thought they were 2000rpm max).
Yup, the Sharkoon 80mm/2000 is louder than the 120mm/1000.Cybertronic said:I'm just wondering
