Silly Hard drive question
23 May 2005
Well guys, i am not to familiar with these new Hard drives i have only ever uses IDE, but i just wanted to know, what is the difference between SATA and SATA II? which one is better and why? do they use different connectors from each other? and do SATA and SATA II work on the same boards or are there a sperate set of boards that work with SATA and another set of boards that work with SATA II?,
Thanks guys.
SATAII is just a faster interface really. There are some features but all in all it's the same as an IDE disk with a smaller cable and higher inerface capacity.
The only real difference to be aware of is that not all SATA controllers are supported by windows. So you have to hit F6 during setup to install the driver else it won't see the disk.
There are various ways of making that process easier but i won't go into them right now.
I'm not sure of the reason for the faster interface though?
Maybe someone can enlighten me, but HDDs at the moment cant even hit sata 1 speeds of 150mbs so whats the point of 300mbs??
Cool, thanks skilldibop, so both SATA and SATA II work on same motherboards i assume?
not absolutely sure here, but I think you would have to check that your motherboard drivers were latest updated to take full advantage of SATAII.
I think you can plug a SATA I HDD into a SATA II board no problem. No idea what happens if you try plugging a SATA II in a SATA I.
1 of 3 things:
1: HDD works but not at full capacity
2: HDD doesn't work
3: The Universe requires a format and reboot [unlikely] :p
SiriusB
My SATA-II sticky at the top of this HDU forum would have answered pretty much all your questions.
