Silverstone micro atx
So it looks like it could benefit from a auto-lineup system like on the Lian Li's then.
Explains why its a Silverstone so cheap though; as they have cut some corners.
Looks great though! Does it have a fan filter?
Yeah there's a bit of foam behind the mesh.
You're right about the LL style clips, but to be honest you're going to be using half the drive bays anyway so you can sort of get away with holding them still and tightening up the screws.
Shame Lian-Li don't make a Micro ATX tower really, all I want is a shorter PC-60 :p
PC50...
G50...
v600...
Lian Li PC-402A and that new cube type one :p
Oh and there is the PC37, and erm...
Smaller than a PC60 :p
I know, just pointing out the fact that Lian Li do small cases :p
I still do not have a clue what there new cube case is called :(
v300 or something.
I don't want a cube :P
Might try and mod these faceplates to attach to the front panel rather than the drive days.
I'm disappointed to hear the cases shortcomings and i'm now swaying as whether to buy it or not. There are no alternative matx towers, as far as i know, and this seemed my ideal case, but now i'm not sure.
For clarification purposes - if there is a drive in the bay - the problem disappears, yes?
