Hire boots, helmet and skis at the resort - saves teenagers trying to schlep ski and boot bags through airports and you can get any issues sorted at the resort.My daughter is off skiing soon please suggest decent clothing, I have no idea what's good.
12 years old,
This isn’t the worst advice I’ve heard in the subject.Image is all, get the credit card out and pray she doesn't like it. Or stick with it and hope she finds a wealthy husband on the slopes to take her off your hands when she's older![]()
Sound adviceImage is all, get the credit card out and pray she doesn't like it. Or stick with it and hope she finds a wealthy husband on the slopes to take her off your hands when she's older![]()
Does it have to be 12 years old or would you consider newer gear?My daughter is off skiing soon please suggest decent clothing, I have no idea what's good.
12 years old,
You want to look for stuff that doesn't fall apart on first use and keeps you warm in the snow, just don't get anything that doesn't have a 4 star or higher reviewsuggest decent clothing
Great jokes aside, this is solid advice. The one thing I'd change is that ski boots (not snow boots touched on at the end of the above post) are probably the most critical part - or to put it another way, the one thing which will either make or ruin your day skiing. Helmets, skis, all the other stuff that goes along with it are mostly interchangeable, cost different amounts but mostly (mostly!) do the same thing to varying degrees. Properly fitted boots, however, are a godsend and your daughter will be unlikely to get them via hiring. If you have the money and the ability to recyle them as her feet grow (younger siblings, sell them on as they retain their value well, etc) then getting fitted boots would be my number 1 top tip.Hire boots, helmet and skis at the resort - saves teenagers trying to schlep ski and boot bags through airports and you can get any issues sorted at the resort.
Layers, lots of layers under a cheap ski jacket and salopettes. No point buying good gear for someone who might hate skiing and will have at least 2 more growth spurts.
Same with gloves. Cheap outer gloves over something fast drying and wind proof like Sealskins.
Buy quality ski socks - at least 3 pairs so that she can alternate them as they dry fully overnight.
Decent winter coat, hat and boots for going out and about when not skiing. Jeans over thermals will be fine. Boots must be highly water resistant. Get her a pair of those snow/ice grip treads that Velcro onto your boots for walking around in the snow and ice.
What's the reasoning behind the avoidance of cotton?layers is key. You don't need to pay top dollar bit you want to avoid cheapest clothing. There are lots of bargains going off brands but look at materials.
Avoid anything cotton is most important advice.
Merino wool base layers can be quiet affordable and will last. Otherwise polyester will be fine.
insulating mid layer, like a polyester sweater.
A puffy down insulator can be good when it is cold.
Outer jacket is best as a shell, which can be used for many activities. Some cheap ski jackets with built in insulation will work, as it is unlikely to rain unless in Scotland . But a good waterproof windproof shell can be used hiking . No need for top end, but the cheapest shells should be avoided.
gloves, anything really but good to get thin glove liners to add warmth.
socks, any skis sock without seams.
Don't forget sun glasses. Of somewhere cold then a balaclava to go under ski helmet
