Synthetics it is then!It is 100% non moisture wicking. It will soak up all the sweat and melted snow and stay soak wet next to the body. At low temperatures, this moisture will freeze and whomever is wearing it is in big trouble.
Cotton is absorbant so if it gets wet, it stays wet. If you're a learner though I wouldn't be going to the expense of wicking base layers such as merino until I knew I was going to stick with it.What's the reasoning behind the avoidance of cotton?
it is a horrendous material, that soaks up all moisture and is difficult to dry. It has very poor insulation qualities even when dry, but is terrible when wet.What's the reasoning behind the avoidance of cotton?
merino base layers can be found cheap and can be used for anything in cold climates.Cotton is absorbant so if it gets wet, it stays wet. If you're a learner though I wouldn't be going to the expense of wicking base layers such as merino until I knew I was going to stick with it.
Makes sense, the kids have been asking about skiing/boarding for sometime next year so all of this is great info.it is a horrendous material, that soaks up all moisture and is difficult to dry. It has very poor insulation qualities even when dry, but is terrible when wet.
Wool is fine though, even when wet is a good insulator. synthetic fibres are not as insulating but dry rapidly and have minimal impact when wet.
I don’t know the OPs circumstances to say whether it’s worth it over the essentials, a 12 year old novice skier doesn’t really need wicking base layers on a first ski holiday, it’s the whole point of layering to stop you sweating and they’re not likely to be hucking it off cliffs or hiking backcountry.merino base layers can be found cheap and can be used for anything in cold climates.
Yeah decathlon is a great shout actually. Loads of super cheap stuff and it’s not terrible.Decathlons another good source - you can get synthetic base layers for not so much, 20yr old Patagonia ones I have , have been alive longer than the merino fad
https://www.decathlon.co.uk/browse/c0-kids/c1-clothing/c3-thermal-underwear/_/N-1aj9j7
Is there a preferred retailer for equipment in the UK or is it just Amazon as always?
under layers are decent from here, especially as she's growing.Decathlons another good source - you can get synthetic base layers for not so much, 20yr old Patagonia ones I have , have been alive longer than the merino fad
