I don't think you can go wrong buying the 5820K, what with DX12 supposed to utilise cores better. Its only another 4 weeks or so till supposed release can you wait and then see some real bench results and Win10 will be available also.
Early benchmarks have shown the 5820K up there with 6700K in gaming at stock.
Plus the 5820K overclocks, a lot. Plus 2 extra cores / threads more cache and is soldered. I don't see the appeal of a similar priced chip with less of everything and poor TIM.
Each to their own, that's just my opinion. Skylake -E will be more appealing to me.
Might be a stupid question but is the Haswell E CPU also DX 12 compatible then? I wasnt sure if this was an advantage that Skylake had or not.
I was thinking about Skylake but now I am wondering about going for an X99 board and a Haswell E instead either a 5930K or a 5960X. Skylake would be cheaper but if the performance of a 5930K would be better and would support things like DX 12 its quite tempting.
and x99 CPU's have no igpu, so its a bit of a moot point when talking about just the cpu and dx12.
BUT, if you have x99 and big cpu you are either going to have a good gpu allready that should be dx12 ready, or you just need the cpu rendering power for encoding or some other simulation work.
I'm still in the market for i7 6700k myself, under water using my i110GT AVX2 and the newer instruction sets I think will start helping more going forwards, and i have the upgrade ich to scratch now!
need to start seeing dual channel ddr4 kits soon as well! I suspect 16GB will be the sweet spot as a new build now, rather than 8GB ddr3 as it was until recently!
Dan
I'm the same as you Dan, already ordered half of my components including a H100i GTX for the 6770k... The only thing I'm still not sure on is what speed I should be looking at for DDR4, as with DDR3 I would probably have went with 2 x 8GB 2133MHz... But with DDR4 I'm seeing numbers all over the place. Also Corsair and Crucial have some 2 x 8GB kits I've seen for sale.
Maybe ~75% faster clock-for-clock on average, with a much higher clock speed if you're overclocking. Only niche applications will benefit from DDR4 but obviously more RAM is useful too.I've waited a long time for Skylake as I'm currently using a Q9550. Looking at the I7 6700K. In real terms, what sort of gain should I be looking at? Since I'll also be changing to DDR4 (8-16GB) (from 4GB DDR3).
Also, Windows 10 is a free upgrade. This means many more people will be able to use the new DirectX version than in the past, when you had to pay for the privilege.
I assume you mostly do gaming? If so, what GPU do you have and do you have an SSD?
