Caporegime
- 18 Oct 2002
Some 4790k chips pull around 1.3v at stock clocks. 4ghz is quite high for a stock speed and turbo.
edit:
I guess 14nm should be pulling a lot less than 22nm.
The chips in the review being compared you have a 4790k at 1.1v at, a 5775c at 1.2v at only 3.5Ghz and the 6700k needing 1.3v to do that clock speed.
In general review samples have always been a bit cherry picked by Intel and I have no problem with that. But if you have three cherry picked chips to the same guy giving maybe the best(lowest) voltage chips around to make a comparison then I wouldn't be surprised if the average Skylake comes in at 0.15-0.2v higher voltage requirements.
They delays and issues with Broadwell have been known about(to varying increasing degrees) over the past 2 years because it was about 2 years ago they were officially pushing back Broadwell by a quarter(then did it again and again) and same with 14nm. Before then there was a lot of talk it wasn't going great but I don't think much talk it was going really badly(for Intel a year delay on desktop parts is considered extremely bad for supposedly the best process company in the business).
The voltage on all the previous 14nm products has been surprisingly high and with bad clock speeds to go along with them so this doesn't come as a huge surprise. However you would hope that Broadwell was effectively canned so they could move on to a 'fixed' Skylake where high voltage/temps wasn't an issue and higher clock speeds would be possible.
