Hi,
So I have the Asus Rampage II Extreme. I also have two MSI FrozrII 470 cards. I'm trying to sli them but seem to be hassles.
First of all, I have tried the cards when not in sli mode and both of them work fine but when i enable SLI in NiVidia's control panel by selecting "Maximise 3D performance" instead of Disable SLI I'm having issues. In Windows all is good and well, but when I try and play any game after about 30 seconds i get a black screen, and sometimes it comes back but eventually it just crashes and i need to reboot. Any Idea what I might have done wrong?
My doubts are,
Am I using the correct sli bridge? My cards have like a double bridge on each but the bridge i seem to have only has one? is there a reason for this?
I have the cards in the 1st and 3rd PCI slot on my board (for better air) is this ok?
Do I need to enable anything in bois for sli to work?
Am I enabling it correctly in the Nvidia Control panel?
Any other suggestions would be great... as you can probably tell by now i have never used SLI before so I'm hoping its something silly like not enabling something in bios maybe!
Thanks!!!
My doubts are,
Thanks!!!
I pulled you up on your quite frankly uncalled for comment, now you trawl through my posts and start on me.
