Sli not working =( help?
Wow, his post was usefull, what's the problem :confused: I pulled you up on your quite frankly uncalled for comment, now you trawl through my posts and start on me.
Have you really got nothing better to do on a Sunday afternoon other than annoy fellow forum users?
I like to know who's having a go at me.
It looks like we're both having busy afternoons.
Ok so i followed the first guide here for SLI and managed to play some wo without a crash which is a lot futher than i was getting last night!!
going to give Rift a try next Wish me luck!!
Also, thanks!!! =D
Good luck.
Sorry about all the crap in your thread.
Ok... so...
I have been only playing WoW and I have been ok playing Rift with no seen issues and SLI clearly working (all settings are quite high)
But... when I just try and load a map in BFBC2 and i get a blue screen every time... Any ideas???
This is the information on the BSOD
Code:
Problem signature:
  Problem Event Name:	BlueScreen
  OS Version:	6.1.7600.2.0.0.256.1
  Locale ID:	2057
Additional information about the problem:
  BCCode:	124
  BCP1:	0000000000000000
  BCP2:	FFFFFA800701E028
  BCP3:	00000000BE000000
  BCP4:	0000000000800400
  OS Version:	6_1_7600
  Service Pack:	0_0
  Product:	256_1
Files that help describe the problem:
  C:\Windows\Minidump\040311-10608-01.dmp
  C:\Users\Solemn\AppData\Local\Temp\WER-14960-0.sysdata.xml
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
The drivers I'm using are the latest ones, Version 266.58
Any idea where I might be going wrong here??? Thanks..
Are you running your system overclocked, if so try it at stock, could be a memory/voltage setting issue. Bfbc2 is a pretty strenous game that will show up any overclocking instabilities.
Have you tried the 270.51 beta drivers?
Nope, I'll give them a go now, ta =)
Nope not running any clocks atm. I do however intend to restore my OCUK profile when i get this all sorted.
Installed new drivers.
Now I am no longer getting a BSOD which is progress, but BFBC2 is just terminating. Once I managed to load a map, was in the game for about 30 seconds, and then i jumped back to windows With the message asking about not using the windows 7 theme because my systems preformance has dropped..
So something must be happening to have windows terminate a game because BFBC2 is using too much resources on an i7 Sli 470 system =/
Any ideas?
Thanks again for all your help with this!
Off to bed in a bit, but i did notice something,
running BFBC2 without sli turned on, I didnt have an issue, but i had SpeedFan running in windows and my Core temps were getting pretty high so then I thought ahh maybe its over heating, so I put SLI back on and had speed fan running in the background again, while in the server list area my CORE temps are 70+... No idea what temps I would be looking when loading a map because I am getting the BSOD again!!!
Anyways, I am just using the stock cooler until I can put my system into my WC rig. But just wanted to make sure all my components were working right before I do that.. I'm still concerned I have a dodgy PSU, anyway I can check that for sure?
Ta guys!
