damascus steel is just a very special kind of heat treated carbon steel so the iron carbide forms a layer that acts as the sharp edge with the iron around it giveing it support and toughness. modern steels are massively stronger and can be made into much better blades. its just about tradition as nobody needs a sword anymore the good replicas etc are made to the technology of the era of the swords not modern day levels.Phnom_Penh said:Nothing in physics makes it impossible. The longest katana I know of is 3.77m long, with a cutting edge of 226.7m. If sharp enough, a blade of that length could easily go through seven people, and with the right cut, like an o-kasa, which is a very easy cut, would cut seven people in half.
I doubt it, firstly "scimitar" was never actually a type of sword, it refers to various middle eastern swords, and the majority of blades were actually thin rather than being wide as they are depicted in films etc. The only way it would be possible, would be if the sword happened to be made from damascus steel, which is possibly the strongest steel compound ever made.
anyway if i was going to make the perfect sword i would be looking at single crystal diamond much stronge and sharper. it would be unbelievably expensive though
sick
