I'm not - but it's the summer, business is a bit slack and I need something to do to keep me busy. Spending £1000 on a metallurgy report to prove Swiftech haven't controlled their suppliers properly sounds as good a way to w[h]ile away an evening as any....
Interesting. It sounds as if you've already decided that Swiftech are merely negligent rather than duplicitous. Many might think otherwise. Allegedly.
the anodization seems to be in name only/QUOTE]
As far as I know they're not actually anodised - more like soaked in dye. That gives no protection whatsoever.
The warning around HydrX seems way too low-key to be able to claim immunity
It clearly says on two sides:
Made in the USA
glad you're getting some good support out of it at least.
I'm slightly worried about opening my GTX to see the damage... was okay about 3 or 4 months ago. I need to drain my loop later this month to add another radiator so I guess time will tell...
