Small side project.
Ok last load of pics for awhile till the rear PSU plate is made and the hdd cage is moved so i can get it totally finished but as of now its up and running. :)
This was rushed but theres snow outside so had to cut in the house.
Now the cooler fits
Last parts, the 150w PicoPSU and 1TB sammy F3.
There was a hole already in the back of the case for the PSU plug so all went together quick.
Cheers.
Thanks guys. The F3 is pretty noisy so may try find a enclosure for it in the case but otherwise its totally silent. Turning the fan down from 1150rpm to 600rpm makes no difference to the noise.
Very nice smart looking build, price is a bit steep though, guess if you wanted to you could skimp on some parts, but you said you didn't want to and it has come out very well.
I forgot to put the wifi card in so had to dismantle and fit that so did alittle cable tidying too.
(Really low apature as shooting hand held so crappy pic)
Just waiting on PSU plate now. I actually found it plays the only old game i play with over 100fps average so pretty happy. :)
holy mother of god.. and i thought my cooler was big in that case :D
(no worries on the pic in the first post by the way lol)
Lol your build totally inspired me to do this. Glad you posted your thread :)
Very nice work Bradley8988, may i ask what kind of camera you used to take those pictures?
Thanks mate its a Canon 400D.
K last update of the build. Its all done and dusted.
First is the Lian-li custom PSU cover made by Tom.
And the finished cube.
Comments and feedback welcome :)
Thanks Brad.
Very smat! No idea how that PSU works, but it's a nice build all the same. I'd change those thumbscrews on that nice new panel on the back for normal black case screws, but other than that it's fairly sweet!
Tis very very cute. :P
