Fair, it seems i was being overly dramatic. Objection withdrawn, your honour.The amount of steam extracted by a hood is tiny. Hardly a concern IMO.
I'll nudge this thread since parents had a smart meter problem, below issue got lost in the woes of the energy thread
Eon Chameleon home smart meter display failing to show electricity Kwhr consumption - always reads zero ?
we power cycled it and restarted in close proximity to the meter, but still no joy, all other readings correct, including electricity used price.
Thanks for the offer - I'll see first if the help line helps them - msg had said back in office on 4th when we called on 29th.I work closely with the EON back office team
I'm sure they are, but seeing kwhrs consumed is easier to digest, than reverse engineering from total electricity price.I wouldn’t worry about the display if the meter is reading and reporting correctly.
After over two years of no electricity readings from my Smart meter, it's suddenly sprung to life.Sorry to say it but you are now a tick in the box marked Smart Meters installed, meaning once it in they don't give two hoots about youI hear its not just EDF that work this way
I'm partly intrigued which IHD data - if any, is provided directly from local meters, versus, all the IHD data is fed back from the Eon cloud.
etc.
My SMETS1 meters were installed in 2014 and only worked for the first year, until I switched provider a year later. Ever since then, they've been dumb meters and no other provider has ever been able to get a reading from them.
So I've arranged with EDF for my SMETS1 meters to be replaced with SMETS2 ones. The exchange should happen in a little over a week's time and, once everything has been setup, I should be able to enjoy not having to submit meters readings again - or at least until these become obsolete and need replacing.![]()
Is it an older smets 1 meter? These are being migrated in mass to the newer system so lots that had been previously inactive are coming back to life!After over two years of no electricity readings from my Smart meter, it's suddenly sprung to life.![]()
No it's SMETS 2. Very strange but I'm glad it's now working.Is it an older smets 1 meter? These are being migrated in mass to the newer system so lots that had been previously inactive are coming back to life!
When the SMETS1 meter was installed, the impression I was given by the installer was that the battery would probably trigger a replacement before the meter itself actually needed replacing - by which time, they would just replace the meter anyway.In theory smets2 will only need replacing because of failure or at end of life. EOL is stated at 15-20 years, that is stipulated by and because of the weights and measures act that metering falls under.
I grew bored of waiting for the supposed end of year of update. I also remain unconvinced that Frankensteining SMETS1 meters is the best thing to do.Is it an older smets 1 meter? These are being migrated in mass to the newer system so lots that had been previously inactive are coming back to life!
They are coming back to life in huge numbers as they are migrated across which is finally progressing and a rate of knots. Bringing them back to life is much bette than replacing them!When the SMETS1 meter was installed, the impression I was given by the installer was that the battery would probably trigger a replacement before the meter itself actually needed replacing - by which time, they would just replace the meter anyway.
I did wonder why mine had started working a year or so ago (smets 1).They are coming back to life in huge numbers as they are migrated across which is finally progressing and a rate of knots. Bringing them back to life is much bette than replacing them!
The good thing is it should now work with energy company moves going forward and will also receive software updates etc.I did wonder why mine had started working a year or so ago (smets 1).
Any idea why my SMETS2 meter would spring to life?They are coming back to life in huge numbers as they are migrated across which is finally progressing and a rate of knots. Bringing them back to life is much bette than replacing them!
Only the gas meter has a battery and should last between 7 and 10 years from Initial production.When the SMETS1 meter was installed, the impression I was given by the installer was that the battery would probably trigger a replacement before the meter itself actually needed replacing - by which time, they would just replace the meter anyway.
Or being broken by a software update because British Gas can't handle a 5 port smets2 meter leading to a new year without heating...
Edit: It's a Chameleon 3 supplied by EDF if that makes any difference.
Nothing to do with BG, the software update was a security fix implemented by the DCC that has broken thousands of 5 hole SMETS2's we (EDF) have been replacing them with a different brand of 5 hole meter.
It was working ok on the night of the 28th, had the welcome to British Gas message come through on the 29th and it's been broke since then. The engineer came out and said it was a British Gas update and he had seen a lot of these recently. He also mentioned British Gas do not do a 5 port meter, so when ever they take over the supply, they turn the 5th port off. Maybe he didn't realise it was a DCC update instead. Although it might make sense, the meter has effectively been without an official supplier while the account was transfered over. Maybe being with a supplier again meant we got the DCC update? End result is they say they have to fit a dumb old style meter to make it work again. Still waiting on them to track one down though!
On another note, thank you (I think it was you) who suggested EDF are taking on new gas customers. Managed to get myself signed up, and on to a variable tariff as well! Am just hoping it all goes ok as the supply situation is in a bit of a mess apparently due to a meter being installed, but with no supplier listed against it. It says the switch is on target, but there will be no supplier to switch from.. fingers crossed!
