Hey there!
Hope you enjoy it!
Regarding moving files over from your pc, your going to have to buy a bit off software from apple that's called PC To MAC that converts all the files into MAC friendly files, its quite cheap at £125, its worth it!
In all seriousness, its as simple as drag and drop from your PC to Mac.
Josh
No. The Mac works off all the same network protocols
...just easier to configure![]()
Nope, network them up with a crossover cable? That's probably the best way.
Yes.
Make sure you enable file sharing / print sharing in the system preferences if you intend on using them features.
On the Mac.
Go to system preferences, then click "Sharing" and do it all from there
Otherwise, all network related stuff is found in "Network". For example, IP address, domain.. all that jazz.
SweetBe sure to take some pictures
I am still considering a macbook! Tommorow im off to the apple store to have a play on one of the macbooks there, so hopefully I'll be more decisive tommorow
Good luck ^_^
My new Macbooks been sat in the UPS depo all weekend it sucks soo bad.
Went the the apple store in the Bullring today and had a play. Walked out with a airport Extreme and a mini DVI -> dvi adaptor
Good days
roll on tomorrow![]()
I had a play on my Touch last time I went to the Solihull store, had to wait a bit to pick up my MBP so sat there looking at emails and playing TTR. The Genius didn't seem amused.![]()
