This I have to totally agree with.
But if already existed and they got it introduced as the standard they didn't actually invent it did they?
oh and DM this is me bringing something to the thread an actual question.
could you point to someone in this thread claiming AMD invented it?
Okay, I am confused now, I thought when AMD announced Freesync that Nvidia said the reason they never approached VESA about making an open standard for variable refresh is because it already existed in the current standard?
What gives?
Standards take a while to do, it's that simple. It's always seemed from the start that vblanking was "coming", it was in the works, and Nvidia didn't wait for official support, they made a simple chip that could do it straight away and get their first.
Everything that vblanking uses is "in" displayport, as there was always a basically unused communication standard within displayport. This is the method which is used to send a message to the screen to tell it the new refresh rate under vblanking. All that needs to happen is it becomes a standard and monitors wanting to be marked compatible with that standard need to listen at the other end of that cable.
Everything physically was there to enable vblanking within display port, there was just nothing pushing monitor makers to listen to said signal and then do something with it. It pushes monitor makers to do more than the bare minimum, well it doesn't, it just raises the bare minimum. Supporting more things means like, work, and effort and those things are contrary to profit(so most companies think).
Vblanking was already part of the eDP standard, I've got work to do so won't break out my googleFu right now so I don't know who came up with vblanking, I don't know who added vblanking support to the eDP standard. it could have been AMD, it could have been Intel or anyone else.
AMD works with the industry on standards because, that is what they've done for quite some time. People pushing performance and wanting to make and sell gpu's not surprisingly want standards for monitors to be pushed forward to make use of the gpu's, making more people want to buy newer gpu's for the new features.
AMD spearheaded getting vblanking approved to the vesa standard for DP(again I don't know if they did the same for eDP), which leads to monitors reacting with a "urrrgghh, effort, I guess we'll support that then because we have to". So the next round of monitors will likely bother to listen and adjust to said signals.
Standards are the most tedious and ridiculous thing in the industry. We should have DP way beyond where it is now. Would I take a double thickness DP cable for 120hz 4k compatibility.... **** yeah. Till recently it was dual hdmi or dual dvi(lol) cables to get 60hz at 4k. They hadn't moved either standard on officially in the past like 5-6 years really and this is some pretty simple stuff IF and only IF all these guys get in a room and just do it. Politics is holding back sooooo many advancements in the industry.
I mean the actual physical difficulties of making 10nm chips or oled screens are huge, but making a cable that can do 120hz at 4k is EASY, like really easy... yet the latter still isn't done, pure politics, not difficulty.
