So what does it take to max Watch Dogs @4K
I would just refuse to use Watchdogs as an indication of GPU requirements over any resolution. The fact Vram usage barely changes between 1080/1440p tells you all you need to know about this poorly developed dog chod.
+1 The game is a Major let down in just about every department. It suffers even more because of the hype that was generated.
The games borked - period
+1
Emm,HardOCP got Watch Dogs to run on R9 290X cards in Crossfire:
http://www.hardocp.com/article/2014..._r9_290x_4gb_overclocked_at_4k/4#.U-UsCWOTE20
The review was done around three weeks ago.
Kaap insists on using maximum AA even though it makes no difference at 4K just so that he can find a use for his 6GB Titans.
Any ordinary user will get it running on a 3/4GB card and see no difference between 8x AA and 4x or none.
Don't be childish.
On the subject of the game itself I quite enjoyed it. Played it on the PS4 mind.
I also played on the PS4. It ran fine and looked decent. It was still a let down for me as i believed to much of the hype. My favourite part was playing hide and seek online (Hacking).
Running 8x AA at 4K is a bit silly, it runs find at 4K on a 780TI / 290X without that much AA, and it makes little to no difference visually.
I wouldn't bank on it, unless something has changed drastically since launch I had 2 options to get this junk game to run on a pair of 3GB 780's...
Use FXAA/No AA + Ultra ~2700mb
Use 2/4x AA + High/Medium ~2700mb
At 1080p
That said the Vram readings were exactly the same at 1440p....perhaps X setting = Y Vram required regardless of res.
In the end I chose hidden option number 3....uninstall it and don't look back.
It can look very good. Especially with TWM features enabled.
Running 8x AA at 4K is a bit silly, it runs fine at 4K on a 780TI / 290X without that much AA, and it makes little to no difference visually.
It may not be necessarily, but of course it still makes a difference. I can tell quite easily the difference between settings at 4K.
At 1080p
Option 3 is what i went for, no reflection on the game-play, its more me in this regard, its not really my thing, every 6 feet along the game presented options for hacking this and that.... while its not compulsory to hack everything i do have that compulsion to do everything, so to me the game-play felt micromanaged, i found it annoying.
Other than that i didn't find it very interesting, i was also unimpressed by the Graphics. and the performance was horrible, typically Ubisoft performance, FPS up and down in huge chunks, very stuttery, jerky game...
Just a horrible horrible horrible game, i didn't keep it long enough to 'learn to get into it'
What the Game or 4K in general?
The game looks Dull, Flat, Gray, Uninspired.....
i couldn't agree more. the flatness and low res textures are horrible. if i play crysis 2 from 2010 or tomb raider from last year and then watchdogs, it is very very flat and some of the textures are terrible. the water looks miles better than the other textures. the pop in when driving is annoying. my 7970 get 30-40fps on max settings at 1080p and it sutters all the time as well.
Oh I agree, once I'd got a near playable state I found my self bored inside an hour of doing the same thing 3 or 4 times.
Provided rock star don't monumentally muck it up, gta5 will remove all traces of this horrid game.
Ok, let's not get silly about it. It's terribly optimised, but the graphics bad? lol. Head scratching stuff. It has better lighting than say BF4. Are those graphics bad?
Look in any window for a laugh. I had a road with cars parked behind me in an industrial area and when i seen the reflection it showed me in a garden with grass and stuff. That's terrible in this day and age for a top title. The Graphics ain't as bad as some are making out but they are not as good as i was expecting.
I've got realtime reflections enabled. A lot of it's been turned off. It's really poorly optimised which is most likely why they removed a lot of the effects before it went gold. It's forgivable in an open world game. Have you seen real time reflections in GTA 5 yet? I think people might be being overly critical because of the bad press. But it's definitely not as good as it could be. Graphics aren't categorically bad though, not a chance.
