GeForce said:Nice overclock
Well it depends whether you mind the system being any louder.
There's no harm in sticking the fan on 100% and seeing how far the chip will go, then knocking it back a bit if you find it's too loud.
Jon
Basically exactly the same program but will fully use both cores.GeForce said:Neither of those programs are multithreaded - so they're only using one core (CPU usage around 50%?).
Scrap Prime95 and download OrthosBasically exactly the same program but will fully use both cores.
No multithreaded version of SuperPI (yet).
Jon
Could even set affinity if you wanted lol. But yea Orthos is the better option.Clairvoyant said:
GeForce said:I limit mine to 55C full load, but I admit to being a tad paranoid.
Definitely not above 60C though
Jon
GeForce said:Seems a tad high. Not dangerously high, but high nonetheless.
My 4400+ X2 @ 2.4Ghz at stock volts, also with the Freezer 64 Pro, only tops out at 45C load after 2 hours of Orthos.
Jon
Naan_H said:...hopefully that will decrease as the AS5 'burns' in. .
