Solar Panel Inverter Battery Setup
3 Oct 2018
Hi All, taking the plunge into solar PV system myself, i had a question.
I have two system options, the biggest difference from my perspective is that FOX ESS is a 5KWH Output capacity while GivEnergy is only 3.6KWH output capacity.
Which setup would you recommend? (Cost for both is within budget and not much difference)
Panels
Tiger Neo N-type 54HL4-B 400-420 Watt All Black
5.04
12 x JKM420N-54HL4-B
420 Watt panels
Option 1 :
Hybrid Inverter, GivEnergy, GIV-HY5.0, 5.000 kW of Total Inverter Power
Battery, Giv-Bat9.5, 9.5kWh of Storage
Option 2 :
Inverter, Fox Ess AIO-H1-5.0, 5 kW Total Inverter Rating
Battery Fox Ess 3 x HV2600, 7.8 kWh Total Battery Storage
7 Sep 2020
Gods Country
Where is that thread? All I could see was the solar queries in this forum. Can you move it?
OP
3 Oct 2018
thanks for the advice but i can see that thread is already so overcrowded with hundreds of posts and my query will just get buried in existing conversations. I would rather leave it here so that i get some response.
