Solar panel production figures
Im going to look at putting a fan up there blowing around the heat sink and see if it helps. Cant hurt for the cost of a usb fan
Not sure you would see enough of a difference to tell.
IMO the only way to do it is to wait for a perfect couple of days.
Day 1 do the first half the day with a largeish fan then remove.
Day two reverse that trend, compare the curves for differences to a non fan equally normal day.
High level cloud etc means the exact numbers of generation are going to be hard to compare, you want to see if you can move the curve for a day with the fan compared to your baseline.
You would need a few repeatable observations I think in order to say it deffo does make a diff.
One thing though, it cannot hurt, keeping the inverter cooler can only help.
My generation curves on clear days are pretty perfect and predictable.
In Aus inverters externally have to be covered with a sun shade, although if that is to stop them overheating or for another reason I dont know. Just noticed all external need one fitted.
Old post about potentially keeping them cooler
A bit expensive and a bit over kill for such a small array like mine
Put your hand on the body work of a car in direct sun, I bet it feels really hot compared to ambient, your panels will be the same - well above ambient.
Well went and looked my panels up and mine are -0.36% / °C
So more impact than I remembered!
I can't find it now but I am sure I read somewhere that typically peak sun your panels would be likely 30 °C above ambient in summer.
Assuming thats correct I would lose 11.1% for those 30 degrees. Doesn't feel that far off.
Actually, I just compared today 16:55 vs the 16th 16:55. Today was very spiky so I selected a time 5 minutes after the start of a spike since I think the spikes can be overstated.
16/6 16:55 4293w
21/6 16:55 4844w
Diff is a reduction of 11.3%! So the typical 30°C seems reasonable
May plot a few other data points to see how they track
Edit to add today was frequent broken sun, 16th was a perfect solid sun all day type day
We had a thunder storm gloom over at 4pm, thought that was it, then half 6 big sun back out so boosted from the 20 we were on to should be finishing on just over 23.
A few middy clouds, then bursts of sun have given me my highest peak so far. Hit 4.7kw briefly at 12:15. Not the highest overall at 27.9kwh, but pretty close.
Still managing to avoid using any power from the grid for June so far.
