Solar panel production figures
Just updated my pvoutput from 1st July when it was installed. Not sure how long it will take to reflect that.
are you on PVoutput warrior??
Only manually and I haven't updated for a while
Will maybe take time out end of Jan to upload it all
There are a couple of guys doing some good work on extracting and providing better data than solax allows so might be able to automate more soon
Thanks for being part of our Saving Session on 23rd January. Here’s a quick look at the difference your efforts made:
  • You saved 1.368kWh, which earned you 3696 OctoPoints – worth £4.62.
You saved 1.586kWh, which earned you 4288 OctoPoints – worth £5.36.
I should get more for the 24th as I used more, stupid formula! :D
Those figures are always going to be skewed though depending when you started sending data to pvoutput if it's across all time.
Started in March? probably got more good days than bad.
Started in October? will be pretty terrible.
Filtering by month or to lowest common denominator is much more interesting if it can do it, as in last X days where we all have data present.
