- 5 Aug 2006
- Kent, UK
14.6 kwh today for us in Kent. Mostly exported as we've been away
I don't but I will consider one when my boiler reaches end of life. I hope to get rid of gas then.Slight derail but do any of you solar gang also use an heat pump per chance?
Im probably getting a house that needs a full refurb and the difference between a brand new gas Vs heat pump makes things pretty close cost wise. Debating if I shouldn't just go gas and solar instead. Air source heat pumps like under floor heating to reach 4.0 cops which adds more cost. I think a hp AND solar would be too much of a cost investment so it's one or the otherI don't but I will consider one when my boiler reaches end of life. I hope to get rid of gas then.
I am hoping there will be more options then however like a stone battery or a roof mounted heat pump........ hell i may just get a hot water tank and IR radiators ....
but a heat pump will likely be on the list to consider . they DO work but your house insulation needs to be good and also as I understand it you don't want microbore pipes in your system if you plan to reuse your old pipes
nice, managed to top battery 4pm but not sure exactly what time as another data gap hit only have a 3.8 system so im between 1-2kw export unless the sun plays silly buggers lol, coming up to 6pm im about breaking even on usage/consumption, at 16:00:57 I was at 2kw exported but up to 2.9 so far now, sun is behind a cloud so only exporting at 145w now lol15 so far but sun is out and bright for Flux time!
