Solar panel production figures
I have the best day today for a while, but still only 2.7kwh
Month is now 11.9 so average is only 2 basically.
Target is 122 which looks way off but I have only seen a couple of short glimpses of sun and the forecast seems to be improving.
Last year at this point I had managed 18kwh, but the month ended at 127 so I have plenty of scope yet!
4kW is good going at this time of the year, I'm still struggling to get above 2.5kW-ish on 4.8kW of panels at the moment. Is that mainly from the Solaredge system?
I would think so, they are at a better angle so do generate a lot more this time of year.
You may well have peaks that are higher, but you just don't see them. Looking at the graphs at 11:18, it shows as 2.864kW, but my Node Red updates every 5 seconds, whereas the graphs only log the data every minute, so will easily miss the peaks in between, if that makes sense.
0.60 today. Thinking about adding two extra panels in the space I've got left. However, even though no scaffolding is needed as its the garage roof I'm not sure on cost benefit adding just two more panels?
