Any suggestions on best way to track historical daily PV generation with a Solax inverter avoiding complivations of battery supply etc? I find the Solax amp to be unclear at best for me
TaEasiest way, dump the statistics for the day to excel, add up the two PV columns then divide by 12 (you need to divide by 12 as they are wh numbers)
Whereabouts in the country are you? Seems a bit high for the UK.32Kwh today on a 10Kw system today and still a little time left
Not far from Leamington Spa... The solcast API predicted 40Kwh for the location so seems accurate, roof is pretty much spot on due south and no trees or neighbouring properties casting shadows on the panels. 25 panels with a 8.8kw inverter.
Happy to be proven wrong if there is a problem with the software this end but seems to stack up with the graphs.
I was pleased and surprised, it was a new system installed the last week of October so had an okay-ish November then I guess like everyone December struggled to clear just over 100Kwh for the month. January is looking much better!I am in Evesham still producing at 9.95kWh SE & SW with 7.3kWh system with SolarEdge monitoring. but I do have trees shading from the road only.
I would be very happy with 32KW, I need to cut down a few trees.
We are doing 10~ on our 5kw south west facing system, so I can well believe a 10kw system sited perfect south could do 32.Not far from Leamington Spa... The solcast API predicted 40Kwh for the location so seems accurate, roof is pretty much spot on due south and no trees or neighbouring properties casting shadows on the panels. 25 panels with a 8.8kw inverter.
