46.2 generated and 25.6 exported.
Patchy cloud this morning but totally clear from midday.
Nice day, although heat limited output:
84.8 kWh
Managed to fit 7 panels to the gable end wall this weekend, just the wiring to sort out
Currently 15.75 kW of panels (39 No.) just adding a further 10 No. to bring it to 19.8kW. Unfortunately, not all are ideally orientated so it's more of a case of quantity over efficiency!That's a huge number! What's your system like?
Heat & shortening days are working against us now!A perfect day today, but well down on my best day, made 44.43 and exported 38.44.
Best day was 57 or 58, can't remember now.
Most of the original setup are spread across flat roof areas, with 6 No. Mounted vertical south facing.
Two No. Givenergy 5 kW Gen3 hybrid inverters each with 2 x 9.5 kWh batteries (38 kWh total).
All panels have Tigo optimisers with CCA and TAP to monitor individual panels.
I nearly broke 100 kWh a couple of times in June.
The sun was the same height in the sky as 30th April, which coincidentally was almost exactly the same weather. 30th April for us did 51.1kWh, today 46.2kWh. It's less, but it only reached 23C here and there was a strong breeze to cool the panels.A perfect day today, but well down on my best day, made 44.43 and exported 38.44.
In my case I have an 11.68 export limit, but when my next lot of panels come online I'll have 15.5kWp of panels. What I'm planning on doing is charging the batteries at a slower rate, so some exported, some to the batteries.
Also due to panel orientation it's very unlikely to reach peak power.
Are you not hamstrung by an export limitation? I have a 5kW limitation and my usage, although quite high, is not anywhere near enough to consume the total generation predicted for my system even on an annual basis and I can neither store the delta nor export it during the really high peaks. A larger system (eg using the flat roof of my garage etc) wouldn't help this at all for me
I admire your system from a numbers POV but I'd love to know how it works out for you overall...
As Ron-ski, I make sure the batteries are relatively low in the morning and when necessary offset higher charging during the peak generation times.In my case I have an 11.68 export limit, but when my next lot of panels come online I'll have 15.5kWp of panels. What I'm planning on doing is charging the batteries at a slower rate, so some exported, some to the batteries.
