- 21 Jul 2005
- Officially least sunny location -Ronskistats
First time I have surpassed the 3kWh mark in weeks!!
Thats mad….but for a commercial system, probably needed.376.98 kWh today
:But your not using that cable to supply solar, unless your exporting to the grid. Anything coming from the solar would be new and different cables.9.9kw today - better than a kick in the teeth!
Quick question for the solar experts - had this back from our installers today as I explained about how everyone is needing to beat Ron-ski...:
regarding your solar unfortunately the DNO have advised you wouldn’t be able to put any more solar in because of the supply cable to your property. This is the main reason of the limit on exportation that has been set on the inverter.
Does this make any sense? We've got an export limit set on our inverter already, so I don't follow why this would limit any further panels? (obviously the last thing I'd be wanting to do is export anything given appalling rates!)
Yes exactly - that's the bit I don't quite grasp.
We've got an inverter that's already set to limit export to X kw, so I could add 100 new panels and nothing would change that and as you say, all the internal cables are nothing to do with the grid?
I get if I was asking to increase the export limit, but I'm not sure what relation panels have?!
If your not changing the inverter, why did you need to ask the DNO anyway???Yes exactly - that's the bit I don't quite grasp.
)EXACTLY WHAT I'M THINKING! VERY SUSPICIOUS!He asked his UK Power Networks guy to speak to the Scottish & Southern guy who then told you no.![]()
Oh good shout - sorry, thought this was the other thread! My bad - sorry for diverting the thread folks, I'll stop!(shouldn't this be in the other thread)
DNO not being flexible, how strange! I imagine its too easy for people to turn the inverter limit off and break things.
From a is it worth adding more panels if you have a limit doesn't it depends on how that inverter limit works, if the extra solar power can charge the batteries (although there will be a limit on the rate they charge at) it could be useful to add more panels, it'll also improve your generation on less than clear days, but you'll be topping out your generation, and the power available to the house, at the inverter limit
