Solar panel production figures
You're not going make much with with that size system, you really need to get as many panels as you can. I'm guessing that as they are 405w panels it's not a FITS system so you can easily alter it without that complication. If you want advice ask in the other thread.
My Solaredge system didn't generate anything, its been my worse day since 3 December 2023, and I had less panels then.
SolarEdge: 0 kWh
Garage: 0.31 kWh
North west roof: 0.22 kWh
House rear wall: 0.03 kWh
Peak power was 0.21 kW at 11:11
Total generated today: 0.56 kWh
Total exported today: 3.552 kWh
Total imported today: 24.993kWh
Yeh and my predecessor got them free under some blag his wife was "ill" - she's not, I know them. This is where it gets worse. That system, on a bungalow i.e. low roof was £7,500 which I think meant that installer just rips off the government. It's 6 panels that are Trian Solar 405w, Solis inverter and the rails and a bit of wiring and then the install. How that was £7.5k is beyond me.
It's not a FITS system, but I'll do some research and maybe pose some questions in the other thread!
Thanks
Thanks
Micky mouse MCS doing their jobs then.
did you have solar panels come down in the storms??
Yes, 3 of the ground mounted panels, alloy bracket gave way that 2 were connected to, falling over taking out the shed panel.
no real damage as they just tipped over onto the grass.
All back up and working now, fixed today.(6 panels total to the house)
Cloudy here today, 0.6kw
Good thing my battery lasts throughout the day, picture from earlier.
Geczt7KW0AAvVzL
1.6 generated, forecast was 1.1 so at least it beat that.
The forecast for the next 5 days is now showing: 1.33, 1.47, 2.90, 1.69, 1.91.
That would leave us over half way through the month and on just 48.4kWh. Just when you thought December 2023 was bad!
