lol, I knew it was gonna be bad for ya but didn't know how bad, tomorrow looks a bit rougherClouds! Clouds! What the hell do they think they're doing! Bugger off.
No, it’s just a blip in the matrix.
Due to owning an EV, flux isn’t really worth it as you don’t get the super cheap overnight rates and the daytime export is lower than octopus outgoing.
I could do intelligent flux but as above, no cheap rate for charging the EV which makes that pretty expensive.
I’m also using electricity for heat so my exports are somewhat dulled. I’m negative on cost but I’m still a net importer. On days like yesterday I was over 50% off peak at 7p with the heat pump so the cost is very low. The rest was covered by solar/battery.
Flux/Intel flux might work out slightly better in 2/3 peak generation months but it’s not work the risk, if I do a lot of miles, it could end up costing more.
I'm finding the ASHP is keeping my 1930s house considerably/consistently warmer than the gas boiler.I changed to Go back in December, before I even considered having an EV, over the year it worked out a lot cheaper than Flux. Now I have an EV I'm on IOG which is a bit cheaper. Fuel cost wise, since mid January the cars cost £15 where I was spending £80 on diesel every three to four weeks. I always fully charge the house batteries overnight at 7p so all excess gets exported at 15p. Heat pump arriving mid April and gas going.
Quite few clouds around today, hopefully still do well on the generation, but unlikely to be as good as other days this week.
I feel it is almost central heating gas boiler switch off soon. Which should limit our costs. But interesting to hear this. Ours is 60s and neighbours with ASHP seem to have been struggling keeping their pad warm.I'm finding the ASHP is keeping my 1930s house considerably/consistently warmer than the gas boiler.
Also same, EV (currently model Y performance) and similar with the batteries.
That's my next step move over to an ASHP - it makes so much sense especially with solar and batteries. If I can remove reliance on gas which is ridiculously expensive then so much the better.I'm finding the ASHP is keeping my 1930s house considerably/consistently warmer than the gas boiler.
The issue will be with the system design, not the heat pump itself, aka, a bad installation or the controls are set up incorrectly for their property which points back to the installation not being the best.Ours is 60s and neighbours with ASHP seem to have been struggling keeping their pad warm.
Yes, definitely down to design ( I have improved some of the insulation over time. More recently putting a new flat roof on an existing 80's extension that didn't have anything at all just a void!.The issue will be with the system design, not the heat pump itself, aka, a bad installation or the controls are set up incorrectly for their property which points back to the installation not being the best.
The age of the property and its relative insulation levels are not really relevant to system performance. Better insulation reduces running costs but that’s not unique to heat pumps.
Unlike a gas boiler the margin for error is small and you really do need to know what you are doing in terms of designing by a heating system.
