£750 for some mesh seems expensive though..
depends if it’s solar skirt or mesh I suppose? Skirt looks smart.
Installers attached mine to the rails.I was advised to buy the mesh separately (sub £200) and whilst scaffolding is up, pop it on myself.
Reasonable. 5kw inverter?I've received a new quote this morning and guidance is appreciated as its the most expensive but also the highest number of panels:
£13,500 plus £50 per panel bird guard
- 6.22kW Solar PV System
- 15 x 415w Eurena Panels
- 2 x 5kWh Growatt AXE Battery
- Growatt Inverter
- 3 x Tygo Optimisers
- Smart Monitoring
- Hies Registration
- Epvs Validation
- MCS Certification
- 5347 kwh per annum
Thanks for the response. Typo on inverter!Reasonable. 5kw inverter?
As I’ve said a few times in this thread Tigo no longer support blind deployment of their optimisers (I’m presuming you have 3 shaded panels?) https://support.tigoenergy.com/hc/en-us/articles/4770355167635-TS4-Systems-Blind-Deployment
If you’re going to have any tigos get your installer to setup Tigo TAP and CCA at the same time so you can monitor and firmware update them.
I've just been running myself around in circles with 6 panels I've fitted to my garage wall - all tested open voltage fine and then with Tigo's connected, but once in series no voltage (not connected to inverter yet).Reasonable. 5kw inverter?
The warranty can be upgraded for around £200 or soTo keep my progress with quotes up to date in order to help others this is my latest negotiated quote:
Total £12,000
- 15 410w Canadian Solar Panels
- Givenergy Inverter
- Givbattery 9.5kwh
- Birdmesh
This appears to be my strongest quote yet based upon output and storage. My main concern's so far, is that I need to check why the Inverter has a 5 year warranty when others have a 10 year warranty. And this quote has no optimizers included. But the roof definitely has some shaded areas as the sun moves round the house.
Ah, thanks for that info.The warranty can be upgraded for around £200 or so
Just a quick extra note on that, it has to been completed within 60 days of commissioning.Ah, thanks for that info.
Haha yes!I've just been running myself around in circles with 6 panels I've fitted to my garage wall - all tested open voltage fine and then with Tigo's connected, but once in series no voltage (not connected to inverter yet).
Realised it's likely to be the Rapid shutdown happening as these are re-purposed Tigo's from my old system and likely need resetting on the portal.
Anyone used Eon for a solar install?
My installer have just signed up to do EON and are now dual branded in regards their workwear.
It seems they work with reasonably large local installers and they are not in house so to speak.
That would worry me to be honest, there are enough parties involved already IMO without adding another.
If I remember correctly you have whole house backup, if so you need the second inverter to be controlled by the first inverter. Say the grid goes down, both inverters carry on generating power, the batteries fill up, the inverter throttles back, but the other inverting carries on generating power, what happens?
In my system the Victron will alter the frequency, its called frequency shifting and my SE inverter will stop producing power, and the Victron throttles back just enough to cover loads.
So you need to make sure whatever you have will do this.
Also the first inverter needs to be able to take excess power from the other inverter and charge the batteries.
Probably the easiest way is to use the same make of inverter, so long as they play nice together, including the above, and also with data collection.
You'd also need to do a G99 with the DNO for the increase in generation power.
Will the town house shade the panels in the winter months?
They just subcontract out the work and all the pitfalls that entails.Anyone used Eon for a solar install?
Must dig around my logs again, but I am reasonably sure that what our Inverter logs show as "Daily ..." are tallies. I've got these:Thanks Ron, yes that was all pretty much my understanding.
I have seen loads of Solax installs with multiple inverters. But no way to know if that includes house backup. They look simpler in the pictures.
I was planning to look at what the "extra boxes" do. They do a number of additional boxes that allow expansion of various parts of the system so assumed there is probably one that will cover this.
I am not playing fully yet however since my batteries again look to be an issue. I am convinced its an issue, maybe something messed up in firmware or just poor QC and quality in general.
I am convinced the "others don't have you issues" is really "others just assume they work as advertised"
Going to dump the batteries, probably tonight, and do a full charge from grid from 10% SOC.
I had another thought. We have only been focussing on the battery charging aspect, ie the charge taken in from 10% to 100% SOC. Thats impossible to perfectly demonstrate since I have some house baseload, and the SOLAX monitoring is 5 minute intervals and seems to be spot values as opposed to average values.
So I am going to do a full charge. But realised if I isolate the solar, I can do a full discharge as well. IE I can allow the batteries only to power the house. With no PV then the total yield will display what the batteries delivered to the house.
Need to find a day with good late afternoon solar prediction. So I can run the batteries down from 100% during the day, but have a chance of topping some decent amounts back up from PV after that has been completed.
I realised I missed a trick. I get on pretty well with the spark who keeps coming round. I should have asked him if he will do some solar himself, I suspect he would from conversation.
Darn it.
I will see, but I suspect that seeing whether - for example - Daily Energy Purchased(kWh) agrees with Octopus should be easy enough.
- Daily Charging Energy(kWh)
- Daily Consumption(kWh)
- Daily Discharging Energy(kWh)
- Daily Grid Feed-in(kWh)
- Daily PV-1 Power Generation(kWh)
- Daily PV-2 Power Generation(kWh)
- Daily PV-3 Power Generation(kWh)
- Daily PV-4 Power Generation(kwh)
- Daily PV-5 Power Generation(kwh)
- Daily PV-6 Power Generation(kwh)
- Daily Production (Active)(kWh)
Obviously, your inverter may do things differently.
