Really, and you keep the same rate?You can even increase the size of your FITS PV installation nowadays, previously you could only change like for like if you had an issue. If you had a 4 kW FITS array and doubled it to 8 kW, then your generation would be paid on 50%, its pro-rata.
What are you guys using for your electric import, octopus?
i also have a 4.6kwh (5.12 90% dod) battery and it's cutting closeWe have a battery but it's only a 5.2kwh givenergy one, so realistically about 4kwh, so I don't think it would be worth going for overnight cheap rates, as I think we might end up getting stung on that?
Agile here. If you dont go for a tariff with cheap overnight rates the only other option is tracker.What are you guys using for your electric import, octopus?
We are on a long fix with EDF but that's about to come to and end. We have a battery but it's only a 5.2kwh givenergy one, so realistically about 4kwh, so I don't think it would be worth going for overnight cheap rates, as I think we might end up getting stung on that?
Yes, but it pro-rata, double the capacity you get paid for half your generation, triple the capacity and you get paid for a third of the generation. This is what I read on some documents, but not heard of anyone doing it, believe you can also have a DC battery but you will need a bi-directional generation meter.Really, and you keep the same rate?
Is anyone tempted to ditch Octopus Intelligent and swap over to Eon Next Drive?
I'm on eon next drive + eon set. Works for my use case as my battery will get me through the 0700-2359 higher day rates.Is anyone tempted to ditch Octopus Intelligent and swap over to Eon Next Drive?
Are you sure eon are only charging 50p daily standing charge? When I last looked the standing charge for the v3 was 60p/day.For me the rates on Eon are:
30.46 day
6.9p night - 7 hours fixed between 00:00 and 07:00
49.92/day
16.5p export
Realistically, a year and we are going into the summer so I’m not going to have any clue for months.How long will it take you get to get good picture of just HP kWh usage at various temps, and are you using solar diversion for water heating over overnight cheap rates?
Standing charges vary by region, I’m in one of the cheaper areas fortunately.Are you sure eon are only charging 50p daily standing charge? When I last looked the standing charge for the v3 was 60p/day.
(I'm on v2 which is 54p/day and 8p/kWh)
Any cheap(??) improvements to this??
How is Eon customer service? How do they pay export? Both of those are good with Octopus so worth considering.Is anyone tempted to ditch Octopus Intelligent and swap over to Eon Next Drive?
