Solid State Drive - Space issues, help!
8 Nov 2006
I have a 40GB SSD i use as the primary drive on my system. When installed windows 7 it used up about 29Gb if memory serves me correctly. I have had it about a year now and slowly but surely my free space has beaten away.
I have deleted/uninstalled just about everything i can and am stuck now with about 350mb free space left!
I am thinking it is windows update that is robbing me of all my space, would this be a correct assumption?
Would there be a way of correcting this (say, install a service pack which would allow me to delete all updates up to that point, for example)?
Are there any hidden folders that i should look at emptying?
I dont have the restore settings on.
Or do i bite the bullet and fork out for another SSD?
cheers in advance
For disabling hibernation, do this:
In the Start menu search box, type "cmd" without the quotes
Right-click the cmd program and select Run as Administrator
In the command line, type "powercfg -h off", again without the quotes
Done both those, will see how i get on with it. is there anything particular i should be looking out for/wary of? Will i see a change in any performance?
thanks for the help
Performance should stay the same as far as I know but don't take my word for all of this. I was new to it too until someone on here told me about it. Have you done the changes and got any more space now?
