1) Can you use normal DDR2 PC2-6400 which is a lot cheaper?
2) Do you void you warranty if you install your own hard drives and RAM?
3) Are they quiet?
4) Is it worth putting a fanless graphics card in to cut down on noise, say a HIS ATI HD 4650 Silent Heatpipe?
5) Is the Mac OS easy to use?
3) Are they quiet?
