Thats the exact location thanks for that surveyor.
Messaged ocuk i am at there mercy.
I thought i might have got some thermal compound some where but i couldnt see any anywhere.
Heres what i did step by step.
I took my old intel stock cooler off was easy enough
I took the back off my case and fitted the back plate to the mobo.
I then cleaned the cpu area with the artic clean stuff. Made sure it was dry and nice and clean
I fitted the mouting bracket to the back plate.
I put the thermal paste on my cpu i used the x method.
I then fitted the heat sync to the bracket and tightend with the mini spanner thing that came with the cooler
I checked the cooler was mounted then pluged the fan into the cpu fan header.
Pluged pc back in reconnected keyboard mouse and so on, powerd up. Sniff sniff wtf is that smell checked the side of my comp i saw smoke coming from the top of my mobo near the ram area. tried to power off using the power button nothing happend so i turned it of by the psu and came on here for help after i had clamed down
