I couldn't be outdone
here's the updated iHam application.
iHam Application:
zipped here
Preference maidenhead location stored by OSX automatically under /User/<Your User name>/Library/Preferences/com.gaiasoftwaredevelopment.iHam.plist so it doesn't span user accounts.
I didn't implement the transparent window (I could implement one - even a circular window if you wanted but that would be overkill).
Known issues:
* when you delete right back to zero characters, it'll leave values in the distance and bearing fields.
* dock icon doesn't have a mask hence the white border
* no localisation currently
* no Help - although there are tooltips if you hover the mouse of the fields in the window.
* funky use of search field means that OSX puts it's own menu in there.. quite why you'd want to spellcheck a QTH.
