Someone Please Help
26 Jan 2012
Plymouth UK
Ok my problem is that i have just built a new ish rig but it wont boot up, it will start but wont give me anything on the screen parts are as followed
EVGA Z68 FTW mobo
EVGA 680 superclocked
i5 2500K
16gb Corsair vengance Ram
AX1200w Corsair
so i just water cooled the whole lot and wont give me anything on my display
The only thing i have to go on its the little number display that is on the mobo says 2E which i imagine is a fault code of some sort but i cant find out what it means
Any help would be lovely
Thanks
Is the 8pin ATX plugged in?
Have you connected the monitor to the GTX680?
Have you plugged two 6pin plugs into the GTX680?
Try shorting the two pins manually with a screwdriver on the board that the power switch connects too
ClearCMOS.
ClearCMOS.
yes the monitor is connected as well as the power to the 680 i can get it to boot up/run as the mobo is lit up fans are going ect but just no picture on the display
keep with one stick for the time being,test each slot but im pretty sure it will boot up from any of the slots using just one stick of ram,try reseating your graphic card
or test without it to see if onboard graphics work,you might need a more updated bios to get the gtx680 working/detected ect
Clear CMOS.
Pull the GTX680 out and use the onboard GFX solution.
Mobo doesnt have onboard graphics
z68? 2500k? cpu and mb will have onboard graphics(built into the cpu graphics chip,hdmi/dvi/vga ports on mb)
Just seen that, thats pretty rubbish to be honest.
I said the same about Gigabyte when they use to do an early range of Z68 boards without any display connectors.
ok so dont know what has just happened but for some reason it has just booted up fine, i will install windows on it and do a few restarts and get back to you guys.
Thank you to all that helped with my problem will let you know if its fixed
right i have my rig all set up and working now but ram wont work in dual channel at all if i put ram in dual channel it just fails to boot which is a pain as i have 16gb of it
Any suggestions
