Somethingtodo’s PSU roundup.
I noticed that there isn’t much info on these forums about power supply units, so I decided to do a round up of them myself, obviously I am not going to include every psu on the market, but I will include quite a few, I hope you find this guide useful. I will include the ouput in amps and watts, the higher the amps, the better, the wattage you need depends on the amount of hardware you have, there is a rough guide here : http://takaman.jp/psu_calc.html?english
Some PSU’s have active PFC;
PFC stands for Power Factor Correction and can be described as using series capacitors to “remove” the effect of leakage inductance that limits the output current. PFC can provide more efficient Power Frequency; in lay terms it means less power is lost.
This is not a detailed guide, the facts I state are correct, but I don’t go into all the over current protection bits etc.
ENERMAX
Enermax365AX-VE
link to pic
DC voltage------------Max Output--------------------Voltage toleration
+3.3V-------------------32A-------------------------------5%
+5V---------------------32 A-------------------------------5%
+12V--------------------26A--------------------------------5%
-5V----------------------1A---------------------------------10%
-12V---------------------1A--------------------------------10%
+5Vsb------------------2.2A-------------------------------5%
+3.3V & +5V-------------185W
TOTAL OUTPUT----------353W
price £45
Enermax465AX-VE
link to pic
DC voltage----------Max output--------------Voltage Tolerance
+3.3V-------------------35A--------------------------------5%
+5V----------------------35A--------------------------------5%
+12V--------------------33A--------------------------------5%
-5V-----------------------1A--------------------------------10%
-12V----------------------1A--------------------------------10%
+5Vsb--------------------2.2A------------------------------5%
+3.3V & +5v------------200W
TOTAL OUTPUT---------460w
price £65
GLOBALWIN
Globalwin Sapphire Super Silent 22dBA 420W
link to pic
DC Voltage------------Max Output------------------Voltage tolerance
+3.3V---------------------26A-----------------------------------5%
+5V-----------------------42A------------------------------------5%
+12V----------------------18A-----------------------------------5%
-5V-------------------------0.5A---------------------------------10%
-12V-----------------------0.8A----------------------------------10%
+5Vsb---------------------2.0A----------------------------------5%
+3.3V & +5v--------------220W
TOTAL OUTPUT-----------400W
price £95
Globalwin Sapphire Super Silent 19dBA 520W
link to pic
DC Voltage---------Max Output------------Voltage tolerance
+3.3V------------------28A---------------------------5%
+5V--------------------58A----------------------------5 %
+12V-------------------30A---------------------------5%
-5V---------------------0.8A--------------------------10%
-12V-------------------1.0A--------------------------10%
+5Vsb-----------------2.5A---------------------------5%
+3.3V & +5v---------260W
TOTAL OUTPUT-------500W
price £145
SPARKLE
Sparkle FSP300-60ATV 300W
link to pic
DC Voltage-----------Max Output------------Voltage tolerance
+3.3V------------------28A-------------------------------5%
+5V--------------------30A-------------------------------5%
+12V------------------18A--------------------------------5%
-5V--------------------0.3A------------------------------10%
-12V-------------------0.8A------------------------------10%
+5Vsb-----------------2.0A------------------------------5%
+3.3V & +5v &12v = 280W
price £35
ZALMAN
Zalman ZM300A-APF 300W PSU
link to pic
DC Voltage---------Max Output------------------Voltage tolerance
+3.3V-------------------28A-----------------------------------5%
+5V---------------------30A------------------------------------5%
+12V--------------------15A-----------------------------------5%
-5V----------------------0.3A----------------------------------10%
-12V--------------------0.8A-----------------------------------10%
+5Vsb------------------2.0A-----------------------------------5%
+3.3V & +5v-----------180W
TOTAL OUTPUT--------300W
£47
Zalman ZM400A-APF 400W PSU
link to pic
+3.3V & +5v-----------235W
TOTAL OUTPUT--------380W
£75
HIPER
Hiper 420TS
link to pic
+3.3V--------------------28A
+5V-----------------------48A
+12V---------------------16A
-5V------------------------0.5A
-12V----------------------0.8A
+5Vsv--------------------2.0A
+3.3V & +5v------------210W
TOTAL OUTPUT----------400W
Price £40 - £45
CWT
link to pic
450W CWT + SATA Quiet Dual Fan AMD/P4 App Active Fan Control Active PFC
DC Voltage-----------Max Output------voltage tolerance
+3.3V--------------------28A---------------------5%
+5V----------------------40A---------------------5%
+12V---------------------20A---------------------5%
-5V-----------------------0.5A--------------------10%
-12V----------------------0.8A-------------------10%
+5Vsb--------------------2.0A--------------------5%
+3.3V & +5v------------250W
TOTAL OUTPUT---------430W
Price £30-£35 (bargain!!)
TAGAN
link to pic
480W Tagan TG480-U01 Whisper quiet 21db Also support 12v EPS/SATA/XEON 3 Years Warranty
DC Voltage----------Max Output
+5V----------------------48A
+12V---------------------28A
-5V------------------------0.8A
-12V----------------------1.0A
+5Vsb--------------------2.5A
+3.3V & +5v ------------240W
TOTAL OUTPUT-----------480W
price £55 - £60
FORTRON SOURCE
Aurora FSP350-60PN
link to pic
DC Voltage------------Max Output------voltage tolerance
+5V----------------------25.5A-------------------5%
+12V---------------------16A---------------------5%
-5V------------------------0.3A--------------------10%
-12V-----------------------0.8A--------------------10%
+5Vsb --------------------2.0A---------------------5%
has 120mm fans
price £45
ANTEC
Truepower 430w
link to pic
DC Voltage----------Max Output------voltage tolerance
+3.3V-------------------28A----------------------3%
+5V----------------------36A---------------------3%
+12V---------------------20A---------------------3%
-5V------------------------0.5A--------------------5%
-12V----------------------1.0A--------------------5%
+5Vsb--------------------2.0A-------------------5%
+3.3V & +5V & +12v = 410W
total output--------------430W
Price £65
Antec Truepower 380watt (Sonata version)
link to pic
+3.3V-------------------35A--------------------------------3%
+5V----------------------28A--------------------------------3%
+12V--------------------18A--------------------------------3%
-5V-----------------------0.5A--------------------------------5%
-12V----------------------1A--------------------------------5%
+5Vsb--------------------2A------------------------------5%
Total Max Output: 380W
price £55
Max load across +3.3v, +5 and +`12v = 360watt
Note: has voltage control on all lines (as opposed to say the 3.3 and 5v being controlled together)
Truepower 550w
link to pic
+3.3V-------------------32A----------------------3%
+5V----------------------40A---------------------3%
+12V---------------------24A---------------------3%
+5v, +12v & +3.3v Max output: 530W
Total Max Output: 550W
£90-£95
Truepower 330w
link to pic
+5V----------------------30A---------------------3%
+12V---------------------17A---------------------3%
+5v, +12v & +3.3v Max output: 310W
Total Max Output: 330W
price £45
Trueblue 480w
link to pic
+3.3V-------------------30A----------------------3%
+5V----------------------38A---------------------3%
+12V---------------------22A---------------------3%
+5v, +12v & +3.3v Max output: 460W
Total Max Output: 480W
price £80- £85
QTEC(i didnt want to do this)
Q-tech 550 Dual Fan Gold
link to pic
+3.3V-------------------30A peak (20A Max)----------NOT Stated
+5V----------------------40A peak (35A max)---------NOT Stated
+12V--------------------20A peak (14A max)----------NOT Stated
-5V-----------------------0.5A-----------------------------NOT Stated
-12V----------------------0.5A-----------------------------NOT Stated
+5Vsb---------------------NOT Stated-------------------NOT Stated
price £25-£40
CHIEFTEC
HPC-360-202
link to pic
-5V-----------------------0.3A
price £22-£25 (WOW!!)
SHUTTLE
shuttle silentx 250w
link to pic
+3.3V-------------------18A
+5V----------------------19A
-5V------------------------???A
-12V----------------------0.3A
+3.3V & +5V Max output: 105W
+5v, +12v & +3.3v Max output: 250W
Supports Intel:SS51G/SS56G/SB52G2/SB61G2/SB62G2/SB65G2/SB75G2
AMD: SK41G/SN41G2/SN45G/SK43G
price £40
My opinions:
Best value~CWT 450W/chieftec 360W
Most desirable~globalwin 520w
Recommended~Antec trupower 430w
Best looking~aurora 350w
anything i have missed feel free to email me [email protected], no spam plz
ENERMAX
Enermax365AX-VE
link to pic
price £45
Enermax465AX-VE
link to pic
price £65
GLOBALWIN
link to pic
price £95
link to pic
price £145
SPARKLE
link to pic
price £35
ZALMAN
link to pic
£47
link to pic
£75
HIPER
Hiper 420TS
link to pic
Price £40 - £45
CWT
link to pic
TAGAN
link to pic
price £55 - £60
FORTRON SOURCE
Aurora FSP350-60PN
link to pic
has 120mm fans
price £45
ANTEC
Truepower 430w
link to pic
Price £65
link to pic
price £55
Truepower 550w
link to pic
£90-£95
Truepower 330w
link to pic
price £45
Trueblue 480w
link to pic
price £80- £85
link to pic
price £25-£40
CHIEFTEC
HPC-360-202
link to pic
SHUTTLE
link to pic
price £40
My opinions:
