Sonata II question and Monitor spray paint query (Operation Black Samsung)
Here's first pics :)
Monitor in original (and base's original) colour:
As the base looks now:
That is not looking half bad mate!
Its turned out a lot better than what I was expecting from the citadel paints, as they are not the best if I think back to my warhammer days!
Thanks. The monitor had a rough texture, all I'm doing is spraying on a coat, with recoats where it looks like its missed it slightly) of Chaos Black spray, and then spraying a layer of 'purity seal' (spray varnish).
Gives a nice, matt black look with a nice sheen as I said :)
Could this be the beginning of a new phase of people of people using cheapy citadel spray paints to get nice gloss black computer parts? ;) :D
Total cost for entire project once finished.
One can of Chaos Black Citadel Spray
One can of Purity Seal Citadel Spray
Some sellotape/ducktape to protect glass screen visor
A bit of time
= £15 or less :)
A nice, cheap mod/paint job done using materials found in the home ^^
That is cheaper than what im planning to do to the wavemaster case!
It does look surprisingly good, however is the blue bit on the top of the monitor a different texture?
If it is you may want to be careful incase the paint takes to it differently.
The blue bit is made of the same material as the case, so when sprayed it should be fine :)
Would only cost £7.50 (think its that for the black) but I decided to varnish for protection.
If I get really bored my go respray my old pc case too, cos thats a creamy beige colour, and I'm not unhappy with the way this black look is coming out :)
Yewen said:
Yeh the varnishing is not a bad idea, gives a longer lasting finnish :)
Tbh, if I make sure I spray the paint so its even, it actually looks damn good, although dust and stuff like that cant always be helped. Its got a tiny blob on one side where some paint pooled, but tbh its hardly noticable, and the paint job looks awesome :)
Cant wait to get the main monitor apart and get it all done :)
Have also discovered that paint cracks slightly if dried to quickly, when I reprayed a little bit on the base, and sped dryed it, but all shall be fine, as its underneath, barely noticeable, has been resprayed, and means I know not to speed dry the main casing (like 30secs) lol just warm dry the main casing over like an hour and all shall be fine :) was fine earlier...just had to have missed a little bit and try to touch it up didnt I? lol
Looking good mate, i cant wait to see the finished product, thats a lot cheaper than buying a brand new moniter just to change colour. Im also thinking of doing this to my moniter, i have a Hyundai image quest Q995 19" moniter and allthough its not beige its silver and grey colour scheme just dont go with my black aluminium case and keyboard. then ill change the green LED to blue and hey presto matchingnes :D .
mark
I have sprayed the vents from all angles, apart from the odd position I missed, its just the flash on the cam reflecting :)
Also, it does have a slight camo effect on the front, but its no way near as visible as the picture, again, thats the flash making things looks worse.
