lens bulk makes the small body pretty pointless.
be careful there, dont jump to conclusion just yet. if the 55mm is as sharp as a zeiss 50mm macro then i would consider it cheap. (although i doubt it....)Just seen the prices of the lenses, ridiculous. $1000 for the 55mm f1.8 compared to the canon at $100 !!!
i dont agree. number of years ago, I used to run around taking photos for magazines/poster design house with a fuji S5 pro with vertical grip(same body as a nikon D200). if the camera body can save me some 50+% weight, i have already considered it as a success. of course, if the lens can also be reduced then it's a win-win, but just body weight-saving is a major step. enough of an improvement i would consider switching if i had to run around again. but unfortunately, the sample pictures aren't doing it any favor.
And you need to be artful when considering weight. A canon 6d and 50mm f/1.8 weight 900g. An A7r with its 55mm f/1.8 weighs 750g. 150g lighter is pretty much meaningless for most people at those kinds of weights. CF an Olympus e-pm2 which weighs 269g and can have many great primes in the 100-200g range, truly. Uh lighter and smaller.
i was going to say their 100mm makro, but i guess thats way too far off. so thats why i said 50mm. but the point is that, if it provide the sharpness up there with the best, then $1000 is in line with the rest of the market or even consider cheap as it has AF.Th zeiss 50mm Makro-planar is a little over $1000 so it can hardly be cheap described as cheap!
The issue with a light body and heavy lenses is it makes the system unbalanced and not very ergonomic. Standard workhorse Lenses like the 24-70mm and 70-200mm f/2.8 work perfectly with you standard FF DSLR. A smaller body won't really help out at all.
i see where you are coming from, and im sure many will agree with you regarding to the unbalanced weight, but from my experience and shooting style i still dont agree.![]()
when i did it as a job, 70-200mm and 80-400mm was often used (and other big lens), even on S5 with grip, it was front heavy. but i never found it a problem as i never gripped very hard with my right hand as it induced too much vibration. i guess my point is that, I for one definitely dont think it is totally pointless to have big lens on a small body as long as it gives me the final image quality.![]()
This completely misses the point. The A7r + 50 will likely provide BETTER image quality WHILE being 150g lighter and SMALLER.
The 6D is about the lightest FF DSLR you can get (partially mag-alloy), and you paired it with a cheap toy like featherweight 50mm lens. This is like the BEST case scenario for the DSLR.
Sony has the wrong idea though releasing slow glass in a bid for more compactness. Not many people with suitable wallets lust after that imo with exception of landscapers etc.
Instead they should have set caution to the wind and made some F1.4 primes & F2.8 zooms (& stabilised), all still being SMALLER than DSLR equivalents.
Just the short flange distance alone gives the a7r etc. and inherent size advantage.
Also regarding balance. Personally I use two hands while shooting. The left hand supports the lens, the right supports the body. I can tell you the Nikon 24-70 + D800E's are anything but balanced. However by using two hands, I am able to comfortably hold such a setup, even more so if it wasn't so heavy.
Lens size is determined by the image circle, focal-length and aperture, plus throw in autofocus elements, stabalisation etc.
Sony should have hired Voigtlander and made a few designs like these auto focus.
http://www.stevehuffphoto.com/2011/...-2-aspherical-ii-lens-review-on-the-leica-m9/
leica adapters are only a few quid, then you can mount any of these lenses on to the sony and basically have a more advanced and up to date leica back![]()
