Sony Blu-Ray Player
james.miller said:
you missed that then huh? i didnt say it was a bluray player that played games, i said it was both. just as sony market it. like that or lump it mate. im not prepared to argue with you about it.
both. not just about games, is it?
http://www.us.playstation.com/PS3/About
I think you'e the one thats missing parts mate.
Burned_Alive said:
The majority of PS3s will be bought for gaming which makes it primarily a games console.
And thats pretty much all there is to it.
it does both, and thats all there is too it. look on avforums, well anywhere really. lots of people buying it for bluray alone and why not? it was (still is?) cheaper than a dedicated unit. whatever you think its main purpose is besides the point. The fact is that is does both very well indeed - enough to make people buy it for uses other than playing games:)
I have to agree, I think it needs basics like 5.1 analogue out, 720p playback, dts-hd support and 1080p over analogue to qualify as a stand alone player.
not supporting 720p bd playback is just sill but your other points? thats like saying a next generation console isnt a next generation console unless it has a hard drive and wifi built in. not really - those are things that some people may want but dont necessarily need. if i can play my blurays in wonderful 1080p without the need for component outputs or analogue 5.1 than that makes it a perfect player for me. As im sure many 360 owners will argue that they dont need built in wifi:)
Burned_Alive said:
So because you bought yours as a blu-ray player, then that makes every ps3 ever made primarily a blu-ray player? No. The majority of PS3s will be bought for gaming which makes it primarily a games console.
So by that logic the internet is primarily a porn conduit?
Actually i think you'll find the point was exactly that, most people buy it for gaming, which makes it primarily a games console. But yes, it does do both, obviously.
Why? Do most people get the internet primarily for porn?
When pretty much every other standalone players have the features, it is not the same as saying the 360 is not next gen because it doesn't have wifi.
Most amps don't have hdmi, hence the need for analogue outputs, loads of tv's only have 1 hdmi, so if thats being used by sky hd or a pc or hd-dvd player, then they can't get 1080p without spending even more on a switcher, and if you are trying to get 1080p on a monitor, then you have no chance.
Jihad said:
You really are an idiot.
Trying to wind people up? It's a humourous advertisement.
I'd say the same if it was Microsoft or Nintendo related but alas, it's not.
You're always quick to "attack" me aren't you.
Grow up you tool.
lol, you can speak, if anyone posts anything anti MS you and Mr Men are the 1st to reply defending it to the hilt, and yes i am always quick to attack you when you post rubbish like this on here just to sit back and await the mischief that you so intended to cause.
then
1st it was "fall down the stairs" and "now grow up you tool" these to me seem your the one attacking me in a childish manner, lol
but you carry on becasue you obiviously need to get it out of your system ;)
i dont have a hdmi amp and not having analogue outputs doesnt stop me watching blueray? and the soudn is still improved over sd dvd's. with a hdmi amp, its only going to get better still.
people who want to get on the net but dont have a wired access point wherever their 360 is will HAVE to buy a wifi adaptor. whats the difference?
people without a wired access point wherever their 360 is will HAVE to buy a wifi adaptor. whats the difference?
If your amp doesn't have hdmi the sound quality is the same as dvds. You need a hdmi amp or be able to use the 5.1 analogue inputs to get hd sound, however the ps3 doesn't have analogue outputs.
no it isnt the same. soundtracks are downsampled to 640k dd (ddplus), or dts where its supported. it isnt the same, you only have to look around at the various comparisons between the two to see that.
Energize said:
They can be upto 1.5Mb/s.
Anyway like I said, no hdmi means no hd sound.
correction. they will be 640kDD (which is the max, dont try to be pessimistic) or 1.5mb/sec dts where supported.
the maximum bitrate for DD on an sd dvd is 448kbps. you do the math - 640k != 448k
If you say so.
yes, 1.5mb dts which is downsampled from the hd soundtrack. again, being better than its equivalent sd dvd, unless something went horribly wrong of course.
So if a standard dvd uses dts 1.5Mb/s and the blu-ray disk also uses dts 1.5Mb/s how do you work out there going to be any difference?
how do you work out they are going to be the same? hd-dvd/bluray and sd dvd sound tracks arent, for the most part, mastered from the same original. you can sit there and argue if you wish, but compare the same disk on both formats - the sound tracks clearly arent the same.
besides, how many full bitrate dts dvd's do you know? most of them arent full bitrate, but rather 768k
If you say so, I can't personally see how they would be any different when at the same frequency, sampling rate and bitrate.
Doesn't change the fact that no hdmi means no hd audio when using the ps3.
Doesn't change the fact that i can still watch blueray in 1080p with amazing sound....that will only get better when i get my new amp. Ill quote myself here:
which is really the only point i made regarding bd playback:) you implied that analogue outputs were needed to watch the movies: that isnt true:)
Sorry Energize but PCM audio is definately better with the PS3, even the games seem to have more dynamic audio over the X360 optical output. Ok i havnt been able to do a 1:1 comparison with the same game but from what ive played PCM is better.
Can i point out though i may be slighly off on this one but BD uses 24bit and DVD will be 16bit audio, though feel free correct me if im wrong.
Also HDMI will only increase in popularity, multichannel is awkward for the general consumer and also untidy. Fair enough it allows external decoding and maintain maximium quality but thats more likely to be a feature on high end models.
Sonys poor issues with PS3
No included HDMI cable
No 720p scaling
No Remote included
All things i think should have been included.
Although I am only connected via Optical, I can say thats both DD & DTS soundtracks sound much more dynamic on BD. I have a few films, including Black Hawk Down, on both formats and the channel separation & clarity of sound is way better on the BD version.
Makes me wonder what delights await when I get around to purchasing an HDMI equiped Amp.
