i copied this from richer sounds
The numbers given relate to the number of HDMI inputs/outputs.8 in/2 out
USBNumber of USB sockets.1
PC InputCan a computer be plugged in?No
when it says pc input no, i assume it means no dvi or vga rather than stopping me connecting the pc with hdmi?
Does anyone know if this amp or another at similar price displays info such as volume, surround mode etc on the TV screen when you make changes. (I cannot see my amp at all as in cupboard)
Earlier reply wasnt clear Thx
All depends on what the DLNA is like and how well it works with WHS on my HP Microserver.
Edit:
Also, can someone tell me whether the Airplay works in standby mode? i.e. can you play music over airplay and it automatically turns on?
I can confirm that it can't I am afraid.
Well, that's damn shame. Bit of a mistake on Sony's part i think. The Marantz SR*008 series has IP Control function, when set to "Always On" it uses slightly more standby power but can automatically come on when DLNA/AirPlay data is sent.
Also, Taylor Swift?..... Seriously?
Edit:
Just found this in the manual:
While the “Network Standby” mode is set
to “On”, the receiver can always be
connected and controlled over the network.
• On: The network function works even
when the receiver is in standby mode, and
resume operations when controlled over
the network.
• Off: The network function turns off when
the receiver is in standby mode. The
receiver takes more time to resumes
operation when powered on again.
Can someone give this ago and see if it works with Airplay? TIA![]()
