Sound problems in Ubuntu
28 Oct 2002
I have no sound even though the system can see the sound card
i have re-installed the nvidia audio drivers but
My 'volume' icon is no longer there
i added another (different i think) volume control button but when i start it i get this message:
"No volume control GStreamer pluggins and/oor devices found"
i have just about all the GStreamer stuff installed and have searched for others mentioning volume control but can't see anything on synaptic that seems relevent
any ideas?
Thanks
Diss
edit
extract from the install log of the driver - is this the cause?
-> The previously installed file
'/lib/modules/2.6.15-23-386/kernel/sound/oss/nvsound.ko' has a different
checksum (1577404839) than when it was installed (2562928459).
/lib/modules/2.6.15-23-386/kernel/sound/oss/nvsound.ko will not be
uninstalled.
-> done.
WARNING: Your driver installation has been altered since it was initially
installed; this may happen, for example, if you have since installed
the NVIDIA driver through a mechanism other than the
nforce-installer(such as rpm or with the NVIDIA tarballs). The
installer will attempt to uninstall as best it can. Please see the
file '/var/log/nvidia-nforce-installer.log' for details.
First thought- have you upgraded your kernel since you first installed your nvidia drivers? If so then you have to reinstall them, and if it's loading the module from the previous kernel build then you may have to rmmod nvsound before proceeding to reinstall the driver.
ok - having a go at reinstalling the linux header and linux image (of same version as boots from grub) - hope thats the right ones - will report back
Diss
PS - do i have anything else loaded that i shouldn't?
root@ubuntu:/home/voteslave # lsmod
Module Size Used by
binfmt_misc 12296 1
rfcomm 40216 0
l2cap 26244 5 rfcomm
bluetooth 49892 4 rfcomm,l2cap
ppdev 9220 0
cpufreq_powersave 1920 0
cpufreq_stats 5636 0
cpufreq_userspace 4696 0
cpufreq_ondemand 6428 0
cpufreq_conservative 7332 0
freq_table 4740 1 cpufreq_stats
tc1100_wmi 6916 0
video 16260 1
acpi_sbs 19980 1
battery 9988 2 acpi_sbs
i2c_acpi_ec 5120 1 acpi_sbs
container 4608 0
button 6672 1
pcc_acpi 12416 0
sony_acpi 5644 1
ac 5252 2 acpi_sbs
dev_acpi 11140 0
hotkey 11556 1
nls_cp437 5888 1
vfat 13440 1
fat 53020 1 vfat
nls_utf8 2176 4
ntfs 103536 2
ext2 68360 1
md_mod 72532 0
dm_mod 58936 1
lp 11844 0
ipv6 265600 6
snd_mpu401 6728 5
snd_mpu401_uart 7808 1 snd_mpu401
snd_rawmidi 25504 1 snd_mpu401_uart
parport_pc 35780 1
parport 36296 3 ppdev,lp,parport_pc
analog 12320 0
gameport 15496 1 analog
snd_seq_device 8716 1 snd_rawmidi
floppy 62148 0
rtc 13492 0
pcspkr 2180 0
psmouse 36228 0
serio_raw 7300 0
snd_bt87x 14664 0
snd_pcm_oss 53664 0
shpchp 45632 0
pci_hotplug 29236 1 shpchp
snd_mixer_oss 18688 1 snd_pcm_oss
snd_pcm 89864 2 snd_bt87x,snd_pcm_oss
snd_timer 25220 1 snd_pcm
snd 55268 122 snd_mpu401,snd_mpu401_uart,snd_rawmidi,snd_seq_device,snd_bt87x,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
snd_page_alloc 10632 2 snd_bt87x,snd_pcm
af_packet 22920 2
bt878 10552 0
tuner 42276 0
tvaudio 23836 0
soundcore 10208 1 snd
bttv 164304 1 bt878
video_buf 22148 1 bttv
i2c_algo_bit 9608 1 bttv
v4l2_common 6016 1 bttv
btcx_risc 5128 1 bttv
tveeprom 15248 1 bttv
videodev 9856 1 bttv
i2c_nforce2 6912 0
i2c_core 21904 7 i2c_acpi_ec,tuner,tvaudio,bttv,i2c_algo_bit,tveeprom,i2c_nforce2
sg 37920 0
tsdev 8000 0
evdev 9856 1
reiserfs 268016 1
usbhid 38368 0
ide_generic 1536 0
forcedeth 23428 0
ehci_hcd 32008 0
ohci_hcd 21892 0
usbcore 129668 4 usbhid,ehci_hcd,ohci_hcd
ide_cd 33028 0
cdrom 38560 1 ide_cd
ide_disk 17664 2
sd_mod 19984 7
sata_nv 9604 15
libata 78992 1 sata_nv
scsi_mod 139496 3 sg,sd_mod,libata
generic 5124 0
amd74xx 15132 0 [permanent]
thermal 13576 1
processor 23360 2 thermal
fan 4868 1
capability 5000 0
commoncap 7296 1 capability
vga16fb 13704 1
vgastate 10368 1 vga16fb
fbcon 42784 72
tileblit 2816 1 fbcon
font 8320 1 fbcon
bitblit 6272 1 fbcon
softcursor 2304 1 bitblit
thanks M0KUJ1N thats fixed the sound - much appreciated
just so i can understand whats going on a bit better can you explain what order things need doing
so, if i upgrade the kernal (through Synaptic) should i (do i) need to reinstall the grapics and sound drivers?
and if i upgrade the drivers do i then need to re0install the kernal??
now that i have learned about rmmod to get rid of nvsound is there also a command to remove the graphics drivers?
many thanks
Diss
grrr this is so frustrating
i did have the sound working - but not the nvidia grapcs drivers
so i reinstalled the restricted linux kernal
RESULT
Nvidia Graphics work
Nvidia sound stops working!!
so i try reinstalling the audio drivers and get thsi:
nforce-installer log file '/var/log/nvidia-nforce-installer.log'
creation time: Sat May 20 16:23:20 2006
option status:
license pre-accepted : false
expert : false
uninstall : false
driver info : false
no precompiled interface : false
no ncurses color : false
no questions : false
silent : false
Installer install prefix : /usr
kernel source path : (not specified)
net kernel install path : (not specified)
audio kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
Using: nvidia-installer ncurses user interface
-> Found package NVIDIA audio driver for Linux-x86
-> Found package NVIDIA network driver for Linux-x86
-> Please select packages for installation:
Selections:
NVIDIA audio driver for Linux-x86 (1.0-7)
-> Starting install of NVIDIA audio driver for Linux-x86
-> Checking for loaded module nvsound
-> Checking for loaded module nvaudio
-> License accepted.
-> Skipping check for conflicting rpms.
-> There appears to already be an audio driver installed on your system (versio
n: 1.0-7). As part of installing this driver (version: 1.0-7), the existing
driver will be uninstalled. Are you sure you want to continue? ('no' will a
bort installation) (Answer: Yes)
-> /proc/version is Linux version 2.6.15-23-k7 (buildd@vernadsky) (gcc version
4.0.3 (Ubuntu 4.0.3-1ubuntu5)) #1 SMP PREEMPT Thu May 18 18:21:31 UTC 2006
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
ERROR: Unable to find the kernel source tree for the currently running kernel.
Please make sure you have installed the kernel source files for your
kernel; on Red Hat Linux systems, for example, be sure you have the
'kernel-source' rpm installed. If you know the correct kernel source
files are installed, you may specify the kernel source path with the
'--kernel-source-path' commandline option.
ERROR: Installation of the audio driver has failed. Please see the file
'/var/log/nvidia-nforce-installer.log' for details. You may find
suggestions on fixing installation problems in the README available on
the Linux driver download page at www.nvidia.com.
i then went into synaptic and installed linux-source 2.6.15.23.35 (to go with my 2.6.15-23-k7 kernal - is that ok?
stuck again :(
Diss
edit
lsmod info
Module Size Used by
binfmt_misc 13192 1
rfcomm 44244 0
l2cap 29184 5 rfcomm
bluetooth 54244 4 rfcomm,l2cap
ppdev 10116 0
cpufreq_powersave 2240 0
cpufreq_stats 6912 0
cpufreq_userspace 6816 0
cpufreq_ondemand 8104 0
cpufreq_conservative 9256 0
freq_table 5152 1 cpufreq_stats
tc1100_wmi 7172 0
video 16644 0
acpi_sbs 20556 0
battery 10308 1 acpi_sbs
i2c_acpi_ec 5440 1 acpi_sbs
container 4928 0
button 6992 0
pcc_acpi 12736 0
sony_acpi 5900 0
ac 5508 1 acpi_sbs
dev_acpi 11652 0
hotkey 11812 0
nls_cp437 6208 1
vfat 14976 1
fat 56028 1 vfat
nls_utf8 2560 4
ntfs 114288 2
ext2 74312 1
md_mod 76244 0
dm_mod 63640 1
lp 12612 0
ipv6 287456 20
snd_mpu401 7112 0
snd_mpu401_uart 8896 1 snd_mpu401
snd_rawmidi 27552 1 snd_mpu401_uart
snd_seq_device 9548 1 snd_rawmidi
snd_bt87x 15944 0
snd_pcm_oss 56352 0
snd_mixer_oss 20800 1 snd_pcm_oss
snd_pcm 96772 2 snd_bt87x,snd_pcm_oss
snd_timer 27204 1 snd_pcm
snd_page_alloc 11592 2 snd_bt87x,snd_pcm
bt878 11224 0
tuner 45348 0
tvaudio 25116 0
snd 60068 10 snd_mpu401,snd_mpu401_uart,snd_rawmidi,snd_seq_device,snd_bt87x,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
parport_pc 38340 1
parport 39560 3 ppdev,lp,parport_pc
soundcore 11040 1 snd
analog 12960 0
af_packet 25224 2
pcspkr 2564 0
bttv 173456 1 bt878
nvidia 4547380 12
agpgart 37072 1 nvidia
floppy 65924 0
gameport 17032 1 analog
video_buf 23108 1 bttv
i2c_algo_bit 10120 1 bttv
v4l2_common 6336 1 bttv
btcx_risc 5512 1 bttv
tveeprom 15504 1 bttv
rtc 14388 0
videodev 10368 1 bttv
shpchp 49376 0
pci_hotplug 30916 1 shpchp
psmouse 40196 0
serio_raw 8132 0
i2c_nforce2 7360 0
i2c_core 23168 8 i2c_acpi_ec,tuner,tvaudio,bttv,nvidia,i2c_algo_bit,tveeprom,i2c_nforce2
sg 40288 0
tsdev 8320 0
evdev 10432 1
reiserfs 284400 1
usbhid 41312 0
ide_generic 1792 0
forcedeth 25860 0
ehci_hcd 33800 0
ohci_hcd 22788 0
usbcore 137476 4 usbhid,ehci_hcd,ohci_hcd
ide_cd 36228 0
cdrom 41504 1 ide_cd
ide_disk 19584 2
sd_mod 20864 7
sata_nv 10180 10
libata 84176 1 sata_nv
scsi_mod 145736 3 sg,sd_mod,libata
generic 5444 0
thermal 14088 0
processor 26696 1 thermal
fan 5124 0
capability 5256 0
commoncap 7616 1 capability
vga16fb 14344 1
vgastate 10304 1 vga16fb
fbcon 44640 72
tileblit 3072 1 fbcon
font 8640 1 fbcon
bitblit 6592 1 fbcon
softcursor 2752 1 bitblit
