SoundBlaster X-Fi 2.18.0004 out now
Permabanned
9 Oct 2006
Norwich
:cool::)
Filename: SBXF_PCDRV_LB_2_18_0004.exe
This download is a driver providing Microsoft® Windows Vista® and Windows® XP support for Creative Sound Blaster® X-Fi™ series of audio devices. For more details, read the rest of this web release note.
This download supports the following audio devices only:
Creative Sound Blaster X-Fi XtremeGamer Fatal1ty® Professional Series
Creative Sound Blaster X-Fi Platinum Fatal1ty Champion Series
Creative Sound Blaster X-Fi XtremeMusic
Creative Sound Blaster X-Fi Fatal1ty
Creative Sound Blaster X-Fi Elite Pro
Added Features:
To find out the Product ID of your audio device and if it supports the following features in Windows XP, click here.
For systems using Windows Vista
Dolby® Digital and DTS® decode re-established for sound cards that included decoding in their Windows XP drivers (Not applicable for products that included a 3rd party software DVD player license in the package).
DVD-Audio playback re-established for sound cards that included the application in their Windows XP software suite (For Windows Vista 32-bit only).
Requires the latest Creative MediaSource DVD-Audio Player software. Click here to download.
Fixes:
Resolves issue of system crash when switching to an unsupported sampling rate in Audio Creation Mode while Dolby Digital Live is enabled.
Requirements:
Windows Vista 64-bit, Windows Vista 32-bit, Windows XP Professional x64 Edition, Windows XP Service Pack 2 (SP2), Windows XP Media Center Edition (MCE) 2005 or Windows XP MCE 2004
Creative Sound Blaster X-Fi audio devices listed above
Notes:
Do not install this driver for Sound Blaster X-Fi Xtreme Audio.
To install this driver
Download the file onto your local hard disk.
Double-click the downloaded file.
Follow the instructions on the screen.
Will try these now on my elite pro, thanks for the heads-up :)
I hope cmss works in vista x64 now, I've had to resort to onboard sound to use my s750's. :o
Wow, I had forgotten how good the quality of sound that the xfi produces was, after using on-board for just a week. Both my HD595's and S750's have been given new life with these drivers. :D
Tested so far and working properly:
asio @ 24 bit 96khz
source based games - hl2, css, tf2
bf2142, audiosurf, bioshock, assasins creed, cod4, ut3, gow, cnc3, supcom, grid and dmc4
cmss works again and without clipping
24bit @ 192khz works without clipping
digital + spdif in from my hdtv/ps3
all inputs work at their max rate and without problems
all 3 modes and their features of the console work fine
wow, so far, so good! :D :eek:
Thank god for this creative may have started giving good support for there customers coz this driver rocks Vista and xp nice one creative:)
what do..
beta audio console
vista apps disk
have to offer?
i've had my xfi music since launch week, only ever installed the driver (and alchemy in vista)
Man you need some of the App's to get the best from it.
Grab the Vista .ISO, you really need try for yourself what you want and what is a waste of time basically.
"Trial and Error", it wont take over you PC or such though.
I only install audio switcher/console/THX from the CD (if no newer version is available) Then install latest driversYou don't need the rest.
ok, bearing in mind, i only have headphones (hd 595's thanks to you guys :) ) and never use it for recording
where can i get it guys?
http://forums.creative.com/creative...Vista&message.id=19680&query.id=554568#M19680
This ISO download has been deleted due to, too much negative posting in this thread. I tried to help people get this software, if you want the software buy it on the creative webstore. nuff said.
-seems to be loads of torrents, but on the dodgy torrent sites
my xfi's been working fine with over 4gb for a few driver sets now, no cackling anymore either :)
with one of my pci slots it wouldn't even install the drivers though, so perhaps try another slot if you're getting problems
If you download from a "Public Tracker" you may end up with "Gay Pr0n" or "Goat.se images" instead of a Creative .ISO (don't know which would be worst).
images
i can't seem to find any info on what the iso is called, i've found a 2007 vista disc, is that what you're using?
if 2007 is fine, i'll just get that iso and mount it in a vm before using it
helmut, added you to msn
