Guys,
I've almost done this on several occasions before but hopefully I'll actually get round to it this time.
Now I've finally got my nav install sorted thoughts turn to uprating the rest of the audio setup in my car. Trouble is I've no idea whats what, what I need, or, well, anything. I don't even have a budget as I don't really know what it all costs.
My nav unit apparently has preout's and sub-out etc.
I'm guessing I'm going to need an amplifier and some speakers. I'd like to impove the bass as well but I'm keen to avoid a sub if possible because it'll be a bit of a pain given the boot is sealed.
The front speakers are 5.25" and the rear speakers, located on the parcel shelf, are 6x9's as standard.
How does all this stuff wire in anyway? I upgraded the speakers in my Mondeo and it was super easy and plug and play - I just took the old ones out and put new ones in but as this time I want to use an external amp I'm guessing it wont be so easy. I'm going to need to run cabling from the front of the car to the amp in the boot and then presumably all the way back from the amp to the front of the car again?
Car is an E39 5 Series.
I am NOT an audiophile but I don't want crappy sound quality. I'm currently listening to music through a Logitech 6.1 PC setup thinking 'This isnt bad!' if that gives you any idea of my level of audiophileness
