Man of Honour
- 23 Mar 2011
- West Side
As for graphics card, if not gaming I would recommend a proper 'workstation' card as the architecture is optimised for best performance in 2D/3D CAD programs, and they have specific performance drivers for these programs too.
I have been using these cards in recent workstation builds and they are excellent for the money - the client is very happy with performance in AutoCAD etc:
AMD FirePro V4900 Professional Graphics Card - 1GB - GDDR5 SDRAM
http://www.overclockers.co.uk/showproduct.php?prodid=GX-011-AM
No in stock at OCUK but they always order them in for me.
its super quick compared to my XPS laptop.
Sooo, My delivery came at around 11am this morning so ive been a little busy. this post is from my new PCits super quick compared to my XPS laptop.
All in all it has taken me around 5 hours start to finish, not bad for a first build if I do say so myself
My back is in bits as I put some cardboard down on the floor; didn't have a big enough table to hand to keep everything in a meticulous manor
I'm not entirely sure what to do next... Do I update everything before I start using casually? is the further testing required?
Brilliant, Glad you enjoyed it, it certainly seems that way.
5 hours is pretty good, i remember it took me a good 4 hours to swap my case (though that was dismantling and building a PC) at one point.![]()
good effort I say...
Ill be honest you don't HAVE to do anything, though i'd suggest these things.
- Check your SSD Speed Make sure its running at SATAIII (non-IDE)
- Make sure something like windows defender is running, that is fine for anti-virus (malware-btyes is also good)
- Download CPU-Z and HWmonitor to check on CPU speeds and Temps. CPU temps around 30C-40C is fine (lower the better).
- Ensure you have the latest Graphics driver (as its onboard you may have to look this up through the intel website)
- Check your RAM speed (this can be done is CPU-Z too). As its dual chanel its will appear as half (1600mhz = 800mhz)..
- POST PICTURES!
All good?![]()
Don't forget to download and install the latest chipset and drivers for your mobo.
http://www.gigabyte.com/products/product-page.aspx?pid=4958#dl
Almost done![]()
Been a long day.
Congratulations on your first build.![]()
I would'nt worry about the TMP temps, it's the temps on the Cores a little further down, which are important. Your's look fine, no problem.
Thank **** for that.
I can finally rip into the complimentary haribo![]()
You need another data cable, the SSD/HDD and DVD drive all need a SATA cable to the motherboard and of course a power cable from the power supply.Edit: I forgot to mention that my DVD re writer just came on its own in some bubble wrap. As I've got the SSD and the HDD, I'm missing a data cable for the DVD or HDD as I've only got 2 data cables with the Motherboard. (I've got the SSD as main) Do I have to buy another data cable? was it missing? or do I just need to plug in the sata cable with the power supply and data goes via that?
